Author Topic: what year carbs are compatible for the 1971 cb750..id like to get a better set  (Read 872 times)
mountaintrout
was wondering if anyone could tell me what other year carbs would fit with the 1971 cb750?
Offline wannabridin
  • Patience made me a
  • -Garrett
other than buying a set of CR's, i'm sure you could make a set of the PD carbs fit.  i'm working on mine right now.  they're from a '77K and going on a '76K motor.  i had to get the '77 intake boots, but i found a good set on ebay.  hopefully with a little massaging, they'll fit just fine!  the benefits to the 77's is they have an accelerator pump and adjustable needles stock.  i hear they run a tad lean, so i'm going to jump up a jet size.  hope this helps!
