Author Topic: Keihin Type 1 550k Carb Linkage Photos Please  (Read 1961 times)
Offline OneWheelDrive
  • A journey of 1000 miles starts with your first carb overhaul.
« on: November 23, 2010, 09:52:12 AM »
Looking for some up close and personal shots of the throttle linkage for 550K carbs.  Looks like they're Keihin Type 1, 022A carbs.  I've reassembled, but need to know where the felt rings and wedge washer go (in the one lateral notch in the rod?).  Also would like to confirm I put the throttle cable holder, heavy spring, and WOT stopper together right.  Intuitively, the way the linkage rod has the notches and slots in it, it would be impossible to do it wrong, but I'm sure I would be surprised.  Is just a light spray of WD-40 ok or a bit of grease for reassembly?
Also, it looks like the slides are bottoming out in the bore too early, making the idle adjust screw not reach the arm on the #4 carb, even when screwed all the way in.  Do I need to back out the adjuster screws more to allow the idle adjuster to come into play?  Or did I reassemble the linkage incorrectly?
I know that's a lot of questions for a simple set of carbs, but only so much information can be gained w/ the Clymer and search function.  I can take some photos tonight if that would help clarify my ?'s.  Thanks!
« Last Edit: November 23, 2010, 10:13:09 AM by OneWheelDrive »
1975 CB550 cafe
1971 CB500 stocker
2008 Ducati Hypermotard 1100S *sold*
1973 CB350F *sold*
1975 CB550K Project "Keeper" *sold*
2010 Ducati Monster S4RS *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
2007 Vespa LX150 *sold*
Re: Keihin Type 1 550k Carb Linkage Photos Please
« Reply #1 on: November 23, 2010, 10:52:54 AM »
With a bit more searching, I found this photo
This looks very much like how everything is installed, but still have the idle screw issue and felt ring question.
1975 CB550 cafe
1971 CB500 stocker
1973 CB350F *sold*
1976 CB360T *sold*
1974 CB550K *sold*
1973 CB750K *sold*
1978 CB550K *sold*
Offline Raef
« Reply #2 on: November 23, 2010, 11:18:42 AM »
the felt rings, if I rembemeber correctly, goes on the shaft between the arm where it enters the side of the carb and the cab body its self. it is the arm that opperates the needles and slides.
attached to the base of the arm is a cup, the felt rides in that cup and is as an insulator/ dust seal between the cup and carb body.
as for the bottoming out isuue the set screws with the pinch nuts adjust slide/needle heights this is also the location for adjustment when you synch your carbs.
Mark
