So my jugs came back from the machinist and my cam chain tensioner blade and guide showed up in the mail! I finally have everything I need to put this all together.
The boring went fairly well. One of the cylinders didn't clean up 100% right near the bottom of the bore, but that's what I get for only going .25mm over. It shouldn't make much of a difference (in the machinist opinion, anyways). I'm hoping to go up another 100CC after the bikes first season anyways. The head had to be decked about 0.0145 to bring everything down to same height as the replacement sleeves. Nice flat surface to work with now, also a tiny up in compression :-p
Well I was buttoning up the top end (finally!), everything was going smoothly. Then as I was in the final stage of torquing the head nuts... SNAP!!!
Heavy duty stud snapped right at the bottom of the threads somewhere between 15 and 20 ft-lbs torque. :-( I was pretty upset when it happened, but no big deal, it came out pretty easily with head and vice grips. I'll have a new one in the mail tomorrow and the top end assembly will commence.
I put a lil bit of wheel grease on the headgasket to help keep it in place (and because this is what I'd been told to do by a few others). After I took it all back apart, I put the gasket in a bag to protect it. Hopefully it will be okay to reuse between now and when I get the new stud.
In other news, here's the oil-line adapter fitted to the right side oil gallery:
Goes right from M20-1.5 to -6AN. It sits about flush with the edge of the cases, but once the lines are attached will probably have about 1" of protrusion. I'll have to make up a frame slider for that side to protect it. Turboguzzi made a good suggestion in just tapping out a fitting or plug for a banjo bolt, which would have probably been the better solution. Alas, I feel I will be sticking with the adapter for now. I also helicoiled the head on the oil feed ports for M10x1.5 banjos.
I also spoke with Mark (Hondaman) about rebuilding my swingarm, I will probably send it out when I get back from my trip to Arizona next week.
Unfortunately, I have to divert funds otherwise reserved for the motorcycle to some essential preventative maintenance for my VR6. I'm at 130,000mi, so I'm replacing the timing chains, clutch, water pump, thermostat+housing, oil pump, accessory belt, tensioner and pretty much everything else that might fail that is difficult to replace with the engine in the car. I plan on another 130,000 trouble free miles from my GTI :-) May not be a motorcycle, but still definitely one of my favourite engines. Nice and torquey, compact, robust and it sounds like an exotic in the higher RPMs <3
