Poll
what colour for my Swarbrick pipes?
gloss black
3 (13%)
low gloss black
14 (60.9%)
SS grey
3 (13%)
Jetcoat silver
3 (13%)
Total Members Voted: 20
Author Topic: CB550 Cafe build - 1st bike build, but not 1st build  (Read 198398 times)
Offline HedNut
  • Underwater Basket Weaving
Re: CB550 Cafe build - 1st bike build, but not 1st build
« Reply #125 on: August 13, 2010, 08:45:45 AM »
Oh another cool build!  Great work tintop....SUPEREXCELLENT stuff you do!
Offline Godffery
  • Godffery's Garage
« Reply #126 on: August 13, 2010, 09:07:13 AM »
Ok, I had a feeling that was your motivation for a remote filter. Who drew up the design? It looks pretty bad ass!
I put a remote filter on my Ice Bike but for different reasons
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Ice+Bike/
R U going to be running a cooler as well?
Thanks for the compliment Godffrey.  The design was a joint effort between Terry and myself.  I sent him pictures and descriptions of what I wanted to do, and he machined up the parts you see, incorporating his ideas.
As for a cooler, to start with no.  However adding one just involves mounting it, and changing the line coming back from the filter.  It would run to the cooler then back to the adapter at the engine front (up & down frame tubes).  Could probably reuse the original line for the return, with a new fitting at the cooler.
Well that's a real nifty idea and it's great to have access to that kind of equipment.
I just noticed your in Canaida witch means you likely wont have much need for an oil cooler  in your climate.
Keep up the postings, I'm digging the technical stuff you guys are doing!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #127 on: August 13, 2010, 09:47:23 AM »
http://forums.sohc4.net/index.php?topic=70436.msg782070#msg782070
Here is my Frankenbike. The remote filter isnt mounted yet. Maybe this weekend. I really like the Terry setup. Too bad there isnt a way of incorporating and oil filter, simple heat sink into that chunk of aluminum. You guys have def. got alot of interest in that design. Great thinking.
Offline Tintop
« Reply #128 on: August 13, 2010, 11:43:31 AM »
Brian I'm just home from my race school, what a gas....the old boy still has it! I showed some young guys the fast way around.
Were you at Shannonville on the Nelson track with FAST on Tue?
I wasn't, but bwaller was.  Sounds some of the young guys are going to get doubly embarrassed.  Not just by some girls, but now some 'old guy'. ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Tintop
« Reply #129 on: August 13, 2010, 11:49:07 AM »
Thanks for compliment HedNut.  Over the next couple of weeks things should really start to come together.  The exhaust just came back, looks great, will post pictures shortly.
Tintop
77 CB550 Cafe build
Offline Tintop
« Reply #130 on: August 13, 2010, 11:56:26 AM »
Not sure about not needing a cooler up here in Canada.  The past couple of days its been 90+F with the humidity reading.  Solving the technical issues has been the best part for me in this build.  Love problems - just means I have to find, or design a solution. :)
77 CB550 Cafe build
Offline Tintop
« Reply #131 on: August 13, 2010, 12:08:58 PM »
Thanks Frankenbike.  Really like where your going with your project; and your blue points cover is going to set off my remote oil filter setup.
The remote filter package was definitely a joint design effort, but Terry's machining skills are what brought it to life.  Have been thinking about adding a tweek or two when it arrives from OZ.
77 CB550 Cafe build
Offline Tintop
« Reply #132 on: August 16, 2010, 05:11:13 PM »
Got to the shop today.  Sorted out more of the wiring, installed some more parts, and got the SS hose clamps ready for the carbs.
The ignition switch installed in its new home.
YSS shocks installed.
Intake clamps shortened, ready for the carbs.  Would have had them on today, except I forgot to take the floats. ::) ::)  Tomorrow.
Swarbrick pipes back from the coaters.  Look great. ;D  Had new clamps made from some 3/8 alloy I had, better then the 1/4 steel that came with the pipes.  Should go on later in the week. :) :)  The header with the clamp was given a lite wipe, the rest will have the same low gloss once wiped.
Tomorrow, finish the carb install, and route the cables.  If the sprocket and chain come in those will go on as well.
77 CB550 Cafe build
Offline Aladinsane07
« Reply #133 on: August 16, 2010, 07:36:06 PM »
Awesome progress.  Those pipes are going to look wicked  8)
Offline Zaipai
    • My Home page
« Reply #134 on: August 16, 2010, 08:12:58 PM »
The whole color combo is going to be sweet! Hope we hear those pipes when its finished!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Tintop
« Reply #135 on: August 17, 2010, 03:47:43 AM »
.: Scott :.
Thanks Scott.  A video with sound has already been arranged, just need to get it making sound. ;) :)
77 CB550 Cafe build
Offline Tintop
« Reply #136 on: August 17, 2010, 06:19:32 PM »
Remembered to take the floats this time ::), so the bike finally has carbs again.  One float pin seemed to have put on weight, and although in came from one of the 4, it wasn't going back.  Had my 46C's handy, so I pull one from there and got the heights adjusted.
Initial setup is using #40 mains with the bottom emulsion tube hole drilled one over / F #98 mains with top emulsion tube hole drilled one over / floats @ 15 / 77 K needle lifted 1 notch.  Still have to fit the velocity stacks.
The new chain and sprocket came in, so I finished my 530 to 520 conversion.  Many thanks to Alex @ Krause Racing.  It slipped on just like a factory piece, even uses the Honda clip. ;D ;D
Also got the solenoid mounted to the underside of the battery tray.  Just need to make a tray for under the seat.  It will hold the Hondaman ignition, and the HID components.  Once those are in place I can start connecting stuff.
Fork brace is out for polish & anodizing.  Once its back the front end can go on for the last time. ;D  Did the bwaller mod to the brake pin, worked great.
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #137 on: August 17, 2010, 06:47:47 PM »
Nice.  Is that an O-ring chain, or old style?  A conversion to 520 O-ring is on my TODO list but I've heard conflicting stuff about clearance.
Offline Tintop
« Reply #138 on: August 17, 2010, 08:21:32 PM »
Thanks Syscrush.  It's an o-ring 520.  bwaller asured me they fit, and he's right, but close.  I had the sprocket made in US by Krause Racing - http://sidewindersprockets.com/, also got the chain there as well.  Sander gave me his contact in Europe, but it ended up costing less buying this side.  Could have got an XR 520 sprocket, but they are narrower, and require some shimming.
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #139 on: August 18, 2010, 08:29:17 AM »
Beautiful, thanks for the pointers and info.  I really like the look of a 520, and like the lower care quotient of an O-ring chain.
Offline Tintop
« Reply #140 on: August 18, 2010, 12:26:04 PM »
The lower care and less lube all over, those were my two reasons for going o-ring.  Having to also go to 520 was a side benefit, but not inexpensive if you want to stay with the 17T front sprocket.
77 CB550 Cafe build
Offline Zaipai
    • My Home page
« Reply #141 on: August 21, 2010, 07:49:36 AM »
Damn Sam, that thing is looking sweet.. Nice work..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline P_Camps
« Reply #142 on: August 21, 2010, 08:41:46 AM »
Hey TinTop lemme know when you get her on the road....
I'm in  Vaughan and would love to take a ride over to see it and meet the man behind this AMAZING Canadian build!!!
1978 CB550
Offline Tintop
« Reply #143 on: August 21, 2010, 09:27:56 AM »
.: Scott :.
thanks Scott - wait till I get the stacks on, they should work great.
77 CB550 Cafe build
Offline Tintop
« Reply #144 on: August 21, 2010, 09:45:53 AM »
Hi P_Camps, thanks for the compliment.  I'm assembling the bike in Trenton, in space I rented from CMR Racing Products.  Makes life easier when I need to make that next special bracket ::), all the fab tools are next door. :)  The location has other benefits in that the water jet / machine shop is only 5 minutes away, and I can walk to the paint & upholstery shops in under a minute. ;)
77 CB550 Cafe build
Offline P_Camps
« Reply #145 on: August 21, 2010, 01:09:51 PM »
cool stuff... well if you ever bring it back to Bolton let me know!!  ;)
1978 CB550
Offline Tintop
« Reply #146 on: August 21, 2010, 01:20:58 PM »
more than likely it will be the 400F that comes back 1st.
77 CB550 Cafe build
Offline Tintop
« Reply #147 on: August 26, 2010, 05:26:16 PM »
Got back down to the shop today.  Finally started on the wiring harness.  Also got over to the waterjet guys to pickup a couple of pieces.
Just have the flasher relay to mount on the back tray.  Trays to hold the HID ballest & the Hondaman ignition waiting final fitting.  They will mount under the seat supports, and use the seat bolts for attachment.  Got the charging system sorted & hooked up.  Will be drilling holes at each end of the circuit breaker panel & fitting grommets. The wires will be pulled through a cover once I know how many will be on each side.  Plan on running all the lighting related wires up the left side of the frame, & the power / ignition up the right side.
Picked up the revised rearset plates.  Will use the prototypes to establish peg position, then do a final drill of the revised plates.  Had some front engine mounts in alloy.  Problem was they were to thick. :(  Had the machine shop face them down to usable thickness. ;)  They should look great. :)  Also got the stack mounts I designed for my FCR velocity stacks.  They need to be drilled, and finished.  Think I will give them a brushed finish.  Still working on an air filter design.  Will probably go with what I know from the race cars, and use either Piper, or ITG filter socks.
Ordered the Aeroquip 'Startlite' hose and fittings for the oil system, & the oil pressure gauge.  Should have the fork brace back early next week, then I can do a final assembly of the front end.  That will only leave mounting the fender to do. :)  Of course that doesn't included doing the final wiring in the headlight. ;D ;D
77 CB550 Cafe build
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #148 on: August 26, 2010, 10:34:54 PM »
Looking good man looking good.
1975 CB750K
Project Back in Black
Offline Tintop
« Reply #149 on: August 27, 2010, 03:41:52 AM »
Thanks Old75_rafate.  Couple of weeks and it should be ready to startup. ;D ;D ;D
77 CB550 Cafe build
