Poll
what colour for my Swarbrick pipes?
gloss black
3 (13%)
low gloss black
14 (60.9%)
SS grey
3 (13%)
Jetcoat silver
3 (13%)
Total Members Voted: 20
Author Topic: CB550 Cafe build - 1st bike build, but not 1st build  (Read 202595 times)
Offline HedNut
  • Underwater Basket Weaving
Re: CB550 Cafe build - 1st bike build, but not 1st build
« Reply #225 on: September 28, 2010, 04:22:49 AM »
VERY EXCITING STUFF HERE! Great write up! The anticipation is killing me....I anxiously await
Offline Flying J
« Reply #226 on: September 28, 2010, 09:19:38 AM »
What oil are you going to use? :D
Offline Tintop
« Reply #227 on: September 28, 2010, 10:00:30 AM »
Castrol 10/40 motorcycle for the initial startup.  1st change will be the same.  After that we'll see.  However, the only time I haven't use Castrol was when they didn't have the weight I wanted in syn for the race TwinCam.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline rachet
  • '77 CB750 F2
« Reply #228 on: September 28, 2010, 10:00:53 AM »
Subscribed!  Great detail.
Rach-
But I need Tacos!  I need them or I will explode!
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #229 on: September 28, 2010, 10:49:09 AM »
Wow, there is a lot going on in this build. Can't wait to see her done, really neat bike.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline Tintop
« Reply #230 on: September 28, 2010, 11:17:48 AM »
Thanks rickmoore24, you and me both on the 'can't wait' part. ;D
77 CB550 Cafe build
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #231 on: September 28, 2010, 11:27:36 PM »
Oh no synthetic! GASP!  don't you know if you use synthetic your bike will spontainiously combust and the bike will spring forth oil leaks from your running lights... sorry folks sorry sorry I had too.  ;D
1975 CB750K
Project Back in Black
Offline Tintop
« Reply #232 on: September 29, 2010, 02:50:39 AM »
Running light leaks!  D#m, and here I spent all that time making sure I wouldn't have a headlight leak. ;D ;D ;D ;D ;D ;D ;D ;D
77 CB550 Cafe build
Offline Flying J
« Reply #233 on: September 29, 2010, 02:12:45 PM »
ANy pictures of your rear brake setup?
Offline Tintop
« Reply #234 on: September 29, 2010, 02:24:04 PM »
Not yet.  Should have some later next week, after the rear sets get sorted out.
77 CB550 Cafe build
Offline Tintop
« Reply #235 on: October 04, 2010, 06:35:51 PM »
Got a couple of things done at the shop today.
1st up was to do the final install of the remote filter mount.  Decided to install the OZ filter that Terry sent.  Just have to install the hose clamp and a new drain washer and its ready for oil.  Also dropped the oil pan and gave it a cleaning.  Wasn't as bad as I had expected, and the screen was actually clean.
Next up was installing the cables.  Had Motion Pro make up a set of throttle cables with the same housing length as the 500, but with the extra free cable of the 77/78 550.  They also offer a clutch cable that is 1 1/2" shorter than stock that fits the drag bar perfectly.  Just not sure of its final routing yet.  After I installed the choke cable, it wasn't closing the butterflies properly, may be a linkage problem. :( ::)
Last on the list for today was to test fit the brake cable MP made.  Need to pick up a heim joint, and a short spring, but the fit is great.  The rear sets should be ready early next week.  Once they are on, I can finish mounting the brake cable.
Still to do - fix choke operation / have the rims balanced now that disks & sprockets are installed / install rearsets / add fuel & overflow lines / install pipes / recheck timing & valves / start it! ;D ;D ;D
« Last Edit: January 18, 2011, 04:49:34 PM by Tintop »
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #236 on: October 04, 2010, 07:09:47 PM »
It's sooooooooooo clean, it seems a shame to fill it with fluids and run it. ;)
Offline Tintop
« Reply #237 on: October 04, 2010, 07:17:45 PM »
Any running at this point in the season will be 'indoors'.  So unless it leaks like a sieve ( ::)), it should still be clean in the spring. :) :)
77 CB550 Cafe build
Offline Mavryk03
  • it's a project 75 Honda cb550k1 cafe, this will never be done
« Reply #238 on: October 07, 2010, 08:39:10 PM »
damn tt that girl is pretty clean and i know i have seen that pts cover  :D looks good
Avi: why do they call him boris the bullet dodger?
Bullet tooth tony: Cause he dodges bullets Avi
Got to love Snatch lol
Offline Raef
« Reply #239 on: October 07, 2010, 09:04:45 PM »
you can call him, tin, top or tintop, but not TT that is reserved for     Too tired
Offline Syscrush
  • Sold. :(
« Reply #240 on: October 08, 2010, 08:07:44 AM »
You're in Bolton, right?
If we get some freakish warm weather in Nov I might like to ride out and have a look at your bike if it's not too much of an imposition.
Offline Tintop
« Reply #241 on: October 08, 2010, 09:42:34 AM »
Yes I'm in Bolton, but the bike is being assembled in Trenton.  Where are you Syscrush?
77 CB550 Cafe build
Offline Mavryk03
« Reply #242 on: October 08, 2010, 02:50:11 PM »
oh my bad
Offline Tintop
« Reply #243 on: October 08, 2010, 03:54:08 PM »
oh my bad
Well at least you used the junior form 'tt', not Two tired's 'TT'. :)  You could use Ttop, but then you would probably have GM after you. ;)
As for the points cover, I really like Frankenbike's work.  Just rec'd a set of silver finned covers, and a beautiful finned blue points one.  A cover for every occasion now. ;) :)
Also rec'd some of his side covers for the 73 750K.  Their the best looking part of that disaster now. ;)  Probably doubled its value. ;D ;D
77 CB550 Cafe build
Offline Raef
« Reply #244 on: October 08, 2010, 06:00:04 PM »
I was just jokin about the tt
Been lurking around the build, it's gonna be a nice ride
Mark
Offline Tintop
« Reply #245 on: October 08, 2010, 08:12:17 PM »
Mark
No problem Mark, I was having some fun with it too. ;D
And you don't need to lurk anymore.  All comments & suggestions are welcome. ;)
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #246 on: October 09, 2010, 07:47:36 AM »
I'm in Toronto.  With my current schedule, an after-work rip out to Bolton would be doable, but Trenton's a bit much. :)
In that case... ;)
I think your bike is awesome and I'm looking forward to seeing it all come together.  When it does, this comment might not apply so take it for what it's worth... But I think that there are a few too many colors going on in your points cover / remote filter mount area on the right side of the motor.  If you've got a silver finned cover now, I suggest swapping that on to see how it looks.
Offline Tintop
« Reply #247 on: October 09, 2010, 09:19:04 AM »
In that case... ;)
Valid observation.  It's one of the reasons I took Frankenbike up on his offer and got the cover(s).  I'm waiting until the pipes are re-fitted, as that will add a lot of dark under that area.  The idea of being able to see the points working is what I like about the transparent cover.  Maybe I should get a clear one and run a poll, with pictures. ;) :)
As for seeing the bike, I make some Saturday runs to the shop.  Spend a couple of hours, then back.  So if you would like to join me one Saturday, send me a PM.
77 CB550 Cafe build
Offline Tintop
« Reply #248 on: October 16, 2010, 05:30:58 PM »
Finally got back down to the shop today, and got a couple of things done.  1st up, was retrieving the wheels from the local Yamaha shop.  I had them dropped off earlier in the week for balancing.  Did a nice job, used spoke weights, instead of the stick-on ones.  Did replace the front axle backward though. ::)
The other big item for today was to reinstall the pipes for the last time.  What a PITA, smiled every time I looked at that remote filter. ;) :)  They sure do look great though. ;D  Tried one of Frankenbike's silver finned covers too.  Humm...syscrush might be right.  When I got the blue cover, I wasn't planning on the remote filter.
Also fitted the brake side rear set.  Need to fabricate a bracket to mount the pedal end of the brake cable.  The rear sets are from Denis at CMR.  The pegs are anodized, with a nice heavy knurl; and the other parts are tumbled.  The toe piece is adjustable for position to suit foot size. 8)  The pickup is adjustable through 360, in 15 degree steps; and you can just make out the stop which allows for fine adjustment.  A really slick setup, glad I waited for it.
Just a couple of brackets to make, and a final electrical check.  Then once through the '3000 mile', and it will be time to press the button. ;D
77 CB550 Cafe build
Offline Flying J
« Reply #249 on: October 16, 2010, 06:14:11 PM »
So what are you going to do about the kick starter hitting the pedals?
