while I'm waiting for the final bunch of parts, decided to get started on the wiring. 1st thing was to reinstall everything removed to flip it, and do the pipes.
because of the serious clearance issues with the original master, installed the new dual master I had. this will also simplify wiring as it has a brake switch built in. also got to put on the bar-end mirrors. routed the clutch and throttle cables.
have changed the head light for an XS1100 unit. I didn't realize how rusty inside, until I posted the picture.
time for some tremclad. this headlight uses an H4 Halogen, which is being changed out to an HID unit. the shell shape is also better for attaching the speedo & tach cables. turn signals will be mounted on the outside of the Thruxton fairing.
started laying out a new wiring harness. to keep things as clean as possible, am going to mount the solenoid under the battery.
1st major issue is that the new rectifier / regulator is in the tail, and the old harness ends at the battery.
have a connector kit coming, and will get some wire to build a new section. Hondaman's ignition will mount under the seat, along with the HID digital ballast/igniter behind.
will be adding a small heat shield between the R/R & flasher. the mounting bolt for the R/R nearest the tail light will also serve as a tray mount. the bolt for the starter relay on the other side will to the same. will put a small spacer below to tighten against. the mounting studs for the circuit breaker panel will also secure that end of the tray.
next week - more of the same, along with making brackets to hold the ignition box, solenoid, and HID unit.
