Author Topic: What is the best drummel piece to strip paint and rust?  (Read 1452 times)
fotoguy79
« on: January 29, 2006, 05:23:23 PM »
Hi.  I have a new frame.  There isn't much rust, but I want to strip off the paint and what little rust there is and also smooth out the welded spots.  I was using a drummel tool, but it seems to go through the attachments rather quickly.  It's been suggested that I use Emery paper, but it seems to me a drummel attachment would be quicker.  Any suggestions?
Offline 6pkrunner
Re: What is the best drummel piece to strip paint and rust?
« Reply #1 on: January 29, 2006, 05:29:24 PM »
You can get Dremel sanding rolls in 60 and 120 grit. I love them, but be careful as they will zap past where you want to go real quickly. Sort of like a very small cutoff wheel. ;D But really the 60 and then the 120 grit really erases rust or blems and makes a nice finish. I suggest practicing on a piece of scrap before going for the real deal.
Offline lrutt
« Reply #2 on: January 31, 2006, 01:27:12 PM »
Are you considering taking the whole frame down, or just the rust?
If just the rust, sand it by hand then use a rust converter. If your going to do the whole frame, take it and get it sandblasted.
fotoguy79
« Reply #3 on: January 31, 2006, 01:49:52 PM »
I am doing it to the whole frame.  Sandblasting won't take care of those unsightly weld marks.  I've seen a web site (Red Baron) where the guy builds his own frame and then smooths it all out with his dremmel, even getting rid of the weld marks, so I am trying to do that.  Also looking to do anything I can by myself.  One of my project goals is to spend very little money.  I am trying to build a nice chopper for no more $3K.  I know it's been done, I just have to spend only what I have to.
Offline 6pkrunner
« Reply #4 on: January 31, 2006, 05:07:18 PM »
Then the Dremel is just the ticket with the tootsie rolls to clean up the ugly welds. For $4 for a 6 pack you can't go wrong.
fotoguy79
« Reply #5 on: January 31, 2006, 05:23:29 PM »
What do you mean tootsie rolls?
Offline 6pkrunner
« Reply #6 on: January 31, 2006, 05:37:18 PM »
Common name given to the sandpaper rolls for the sanding accessory.
fotoguy79
« Reply #7 on: January 31, 2006, 05:39:31 PM »
OK.  Thanks.
Offline Paul
« Reply #8 on: February 01, 2006, 01:11:20 AM »
You are doing the whole bike with those.... :D
When you say you want to smooth out the weld spots, I trust you don't mean smooth down the joints where the frame is assembled.
I had a guy do that once and couldn't understand why the joint failed.  ::)
Whole frame....sandblast and then concentrate on the "Blemishes" not the "Welds"
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
« Reply #9 on: February 01, 2006, 03:38:20 AM »
Well said Paul, I've seen dickheads "smooth" most of the welds right off their frames, then wonder why I asked them what was actually holding their bikes together?
Unless you really know what you're doing, either leave it alone, or take it to a reputable engineering shop, and have them reweld the joints and smooth off the excess material. Cheers, Terry. ;D
Offline 6pkrunner
« Reply #10 on: February 01, 2006, 03:42:17 AM »
Before jumping all over the guy, maybe he is going to build up the weld areas and then smooth the weld area out. While there are some out there that may do as you mentioned, that's just Darwin's way of removing the chaff.
« Reply #11 on: February 01, 2006, 03:53:36 AM »
Not jumping over this guy at all 6P, (but thanks for jumping on me.......not.) he's obviously a novice, and I believe it's our responsibility to advise against dangerous practises before they become victims of their own inexperience. Look after your own, but also look before you leap. Cheers, Terry. ;D
fotoguy79
« Reply #12 on: February 01, 2006, 04:53:19 AM »
I appreciate all of the input.  I am planning on smoothing out the welds and while I am a novice, I have quite a bit of common sense, though your comments were still appreciated since they were for my safety.  The welds are already built up quite a bit and I am only going to hit them lightly, anyway.
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #13 on: February 01, 2006, 05:27:40 AM »
Rather than grind the frame welds down.....why not fill them with body filler....then sand it smooth.
I dont know that I would be grinding down any weld material on frame joints...built up or otherwise. Just about any builder will have a body man fill a frame....rather than grind it down. You will get a much more professional look with filler.
...just my 2 cents.
Later,
Greg
Offline 6pkrunner
« Reply #14 on: February 01, 2006, 05:55:47 AM »
Whoa Terry - not a slam at you at all, I read your post and thought he guy may have a clue. My comment "Before jumping all over the guy" was meant for a board wide read - not toward you.  No reflection towards you at all. I don't jump on people - especially through keyboards. Sorry if you took it the wrong way.
But I do appreciate your witty comeback.
« Last Edit: February 01, 2006, 05:57:56 AM by 6pkrunner »
Offline dusterdude
« Reply #15 on: February 01, 2006, 10:07:17 AM »
o yea,he`s a witty fellow alright.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
fotoguy79
« Reply #16 on: February 01, 2006, 05:05:00 PM »
...just my 2 cents.
Later,
Greg
I'll look into it.  That may work since I don't plan to powder coat the bike.  I plan to paint it myself.
Offline Paul
« Reply #17 on: February 02, 2006, 03:58:49 AM »
OOhhh. so Just 'cos I brought it up... It's All MY Fault Now..  >:(   :D :D
Paul.
Offline dusterdude
« Reply #18 on: February 02, 2006, 10:00:44 AM »
yea thats it,it sure is. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
