Author Topic: Clutch problem: CB500  (Read 6948 times)
Offline Scott S
« on: May 06, 2010, 12:41:44 PM »
 I tried to do a preliminary clutch adjustment on my '71 CB500 today and ran into a couple of problems.
 First, the cable holder on the actuator had been buggered up. The cable kept snapping out of it and when I tried to crimp it tight, I broke it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: Clutch problem: CB500
« Reply #1 on: May 06, 2010, 12:43:47 PM »
 I removed the actuator and drilled out the rivet. I replaced the cable holder with one from my Yamaha XS650 parts pile. I had to slightly enlarge the hole in the actuator arm. The Yamaha holder is a much better design and is held in place with a cotter pin. It's ~2mm longer than the Honda holder, but nothing I shouldn't be able to adjust out.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #2 on: May 06, 2010, 12:47:17 PM »
 I noticed the actuator arm was bent and didn't give the cable a straight shot. Repaired that and reinstalled everything. Liberally greased the actuator, ball bearing, pushrod, etc.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #3 on: May 06, 2010, 12:56:46 PM »
 Here's the second (and currently unresolved) problem. I adjusted the clutch per the manual but it doesn't seem to be engaging ( or is it DIS-engaging....).
 I have the 2-3mm freeplay at the lever. I bottomed out the screw on the side cover and backed off 3 mm (meaning, if the screwdriver slot was at, say, 1 o'clock, I moved it counter clockwise 3 mm and then tightened the set screw. Sound right?)
 I adjusted the cable at the case and at the lever as best I could.
 When I pull the lever, it gets FIRM; like a well bled brake lever firm. It's like it's not pushing in the pushrod to activate the clutch. I can put the bike in 1st or 2nd gear, pull the lever in and the wheel will NOT turn.
 The engine is not stuck. I can turn it over by hand or with the starter. I can get at least 1st and 2nd gear.
 This bike sat for almost 30 years. I'm wondering if something in the clutch basket has gotten stuck? Think the plates may be frozen together?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #4 on: May 06, 2010, 12:58:09 PM »
 I plan to pull the left side cover again soon and watch the actuator move with the clutch lever and see what it looks like.
 I'll also check the pushrod and see if it's OK.
 Any idea as to what might be going on or do I need to pull the basket?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #5 on: May 06, 2010, 03:59:14 PM »
 I would really appreciate some ideas on this one. I really want to pull the clutch basket as a last resort.
 Help?
'71 CB500 K0
'81 Yamaha XS650
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #6 on: May 06, 2010, 04:25:18 PM »
What is the conditionof your cable?
Could it be binding?
They feel tight when they get old and worn, it may need replacing.
Bikes parked out front mean good chicken-fried steak inside.
Offline Scott S
« Reply #7 on: May 06, 2010, 04:27:33 PM »
 Cable is brand new. Think it could still be binding? Maybe need to lube it up really well?
 It gets to a point and I just don't have the hand strength to close it anymore and if I did it feels like I'm just stretching the cable.
'71 CB500 K0
'81 Yamaha XS650
Offline number13
    • Sound Exchange
« Reply #8 on: May 06, 2010, 04:49:06 PM »
It certainly could be binding, check the routing there.
Has this bike been working up till now? Is the clutch pack frozen?
Offline Scott S
« Reply #9 on: May 06, 2010, 05:26:55 PM »
 This bike has been parked for 28+ years. That's my concern....something in the clutch basket has "become one" with something else while it sat.
 The bike was kicked over from time to time when it sat, but that still leave LONG periods of time when at least part of the clutch basket was not submerged in oil.
'71 CB500 K0
'81 Yamaha XS650
Offline smileswithadimple
« Reply #10 on: May 06, 2010, 06:02:53 PM »
Maybe run a few caps of seafoam in the oil and see if that helps free anything up? GL!
72 CB500/4
Offline Scott S
« Reply #11 on: May 06, 2010, 06:08:08 PM »
 I plan to attempt to start the bike next week. You think simply getting some heat in the engine and letting it run on the center stand may help the clutch basket?
'71 CB500 K0
'81 Yamaha XS650
« Reply #12 on: May 06, 2010, 06:25:49 PM »
Well I know heat helps many a things get un-stuck, and seafoam is a miracle liquid that will free stuck pistons, so its worth a try?!?  But I truely think its an adjustment issue rather than the latter.  GL!
72 CB500/4
Offline Scott S
« Reply #13 on: May 06, 2010, 06:27:43 PM »
 And I hope you're right?
 Let's do this: Someone talk me through a complete adjustment, step by step, and see if I can get this thing to work correctly.
'71 CB500 K0
'81 Yamaha XS650
Offline raptor4568
« Reply #14 on: May 06, 2010, 11:54:04 PM »
Did you download the manual from the faq?  It's all there step by step.
I'd also run it for a while if you can, it sure can't hurt.  You're going to run it soon anyway, so why not do it before you get into the clutch.
I just tore into the clutch basket on my 73 500, after putting it off for a couple of years.  It's not too bad, other than the terrible seized screws.  I have strange springs in mine (much longer than spec), even though it didn't look as if anyone had opened it.  Your problem might be obvious too once you're there, and it should really only cost you a new gasket to find out.
Good luck with it.
Offline Scott S
« Reply #15 on: May 07, 2010, 03:39:16 AM »
 You mean the manual in the FAQ at the top of this forum? It doesn't work. Download is incomplete and all it shows is a bunch of gibberish.I have a manual (Chilton or Clymers...can't remember, It's out in the garage).
 What about the large adjusting screw with the lock bolt  on the side of the case? Is it supposed to be "pre-set" or in a certain position when the actuator has been removed? I noticed that it doesn't have much "travel". For instance, if one side of the screw slot is at 10 o'clock, it only moves to about 1 o'clock. That's full travel from fully open to bottomed out. Does that sound correct?
 And when they say "back it off 3 mm", does that just mean to move it counterclockwise back from 1 o'clock about 3mm? So now it's just after high noon, so to speak?
'71 CB500 K0
'81 Yamaha XS650
« Reply #16 on: May 07, 2010, 04:30:04 AM »
Look in the bulletins, i know ther is one in there about the adjuster
Offline Scott S
« Reply #17 on: May 07, 2010, 04:52:22 AM »
 This is all I see on the FAQ page:
http://forums.sohc4.net/index.php?topic=260.0
 Not much there to help me on this problem....
'71 CB500 K0
'81 Yamaha XS650
Offline Kirby
« Reply #18 on: May 07, 2010, 05:48:04 AM »
Scott, if you have a new cable, and it moves freely when not hooked up, it should be ok.  Your new homemade clevis looks great by the way, but make sure it is not reaching to and binding on the case protector plate.  I would think your cable housing should be adjusted much closer to the housing, and initial slack taken up with the main clutch adjuster on the center of the housing.  Then if you feel like you are not getting "normal" full pull on the lever, then it is on to the lifter rod that goes over to the clutch, and the clutch discs themselves...Hasn't run for 28 years?...yeah, something might be stuck.  I think you need to open up the right side.  Good luck
Offline Scott S
« Reply #19 on: May 07, 2010, 06:56:11 AM »
 Can you clarify this a little bit? I take it you mean the small adjuster nut in this pic?
 And by main clutch adjuster, do you mean the large screw on the side of the case?
'71 CB500 K0
'81 Yamaha XS650
« Reply #20 on: May 07, 2010, 08:36:18 AM »
You will find the bulletins here. Dont just search the forums for info the search function only works in the section you are in
http://www.sohc4.net/index.php?q=node/324
Offline Jordan
  • What a Long strange trip it's been
« Reply #21 on: May 07, 2010, 09:12:05 AM »
just a thought, that extra 2mm in length and straightening the arm could be causing not enough rotation to engage something. If you backed the adjuster off 3mm shouldn't you need 5mm+ to compensate for the added length? then straightening the arm added more length, it could be causing the whole thing to hit the inside of the case instead of rotating the arm far enough to engage something?
Offline Scott S
« Reply #22 on: May 07, 2010, 09:56:13 AM »
 Is the arm supposed to be bent? The way it was, there wasn't a straight shot from the cable to the actuator.
 I just assumed that it had been bent/damage, going from the looks of the Clevis.
 Maybe someone can give me a good pic of what the arm is supposed to look like?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #23 on: May 07, 2010, 10:03:41 AM »
 Thanks Bryan, but those don't show me anything as far as the adjustment procedure. It's just a service bulletin about the adjuster.
 Is the lifter/clutch arm SUPPOSED to have a bend in it? Did I screw up by straightening it?
'71 CB500 K0
'81 Yamaha XS650
Offline Jordan
« Reply #24 on: May 07, 2010, 10:10:22 AM »
I have a 73 the cover is in a box somewhere, so after I fix my lawn mower, I will attempt to take a photo, no guarantee mine is the same or in worse shape, I haven't even got that far into it yet. Jordan
