Author Topic: CR29 tapped hole  (Read 2142 times)
Offline kmoll70
CR29 tapped hole
« on: May 06, 2010, 04:59:18 pm »
I just mounted up a set of CR29 carbs and while I was hooking up the fuel lines i noticed an open tapped hole in one of the carbs, which is blanked off on each of the other carbs.
Each Carb has an air screw to one side of the inlet
and 3 out of 4 have a corresponding blanked off section on the other side of the inlet
However 1 out of 4 has a tapped hole oppostie the air screw
This hole must have a purpose.
Can anyone help?
74 cb750
Offline nokrome
Re: CR29 tapped hole
« Reply #1 on: May 06, 2010, 11:27:50 pm »
that is a good question, i noticed that on my cr's too, at first i freaked out because i thought that i lost a screw
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline kmoll70
« Reply #2 on: May 07, 2010, 03:53:22 am »
Well that is kind of what i thought to
I assume you are running them with this hole open?
I can only imagine that this hole has to serve some purpose or they wouldnt have gone through the exercise of tapping it
74 cb750
Offline iomtt9
« Reply #3 on: May 07, 2010, 06:36:47 am »
Hi if its a tapped hole on no 2 carb its for a little retaining bracket to hold / stop the fuel pipe from moving.
Hope this helps
Col
Offline iomtt9
« Reply #4 on: May 07, 2010, 06:39:31 am »
I just noticed on your last pic that theres a groove on your fuel line, this bracket fits in there
Col
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #5 on: May 07, 2010, 12:08:55 pm »
Hope this helps
Col
You are right Colin
http://www.sudco.com/Diagrams323728/expcr.gif  See nr; 63  and 64
You meet the nicest people on a Honda
Offline kmoll70
« Reply #6 on: May 07, 2010, 07:33:40 pm »
Thanks guys
74 cb750
