Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 111338 times)
Offline SohRon
Re: Norwegian cafe.. Oil tank in the swingarm....
« Reply #350 on: December 29, 2011, 08:12:48 AM »
there ment to be a gab...it is shown in honda manuals..the way it must be..just as here
god jul i norge..det pis regner i danmark
God jul :) Her er det pluss to grader og duskregn, det lille vi har av snø er på vei bort :)
Gap is correct but must be oriented to the rear... it's backwards in the pic. Really would like more info on the in-arm oil tank. Looking good so far!
« Last Edit: December 29, 2011, 08:16:54 AM by SohRon »
« Reply #351 on: December 29, 2011, 08:25:47 AM »
There is a bone of contention as to the gap. I agree, was always raised to put it in the rear. However, Hondaman holds that Honda told him it goes to the front. There have been discussions as to the physics of front vs rear, favoring the front.
Some clamps have arrows. Assuming the arrow goes forward, that usually puts the gap in the rear. But not always, IIRC.
PS: I'll take this opportunity to sy to anyone who might not know, do not try to close this gap by overtightening the nut. You'll stress the stud, possibly break it. Torque the non-gap side first. Then torque the gap side and STOP.
« Last Edit: December 29, 2011, 08:27:35 AM by MCRider »
Offline SohRon
« Reply #352 on: December 29, 2011, 08:43:47 AM »
Never heard that; all of the info I've seen from Honda (and others) states pretty unambiguously that the gap goes to the rear, with the front bolts tightened first, no matter what bike and, logically it makes more sense for (limited) protection of the axle shaft from the elements, though I'm sure there are better reasons to do it this way. If you have different info, would be glad to see it.
« Last Edit: December 29, 2011, 09:22:05 AM by SohRon »
    • http://forums.sohc4.net/index.php?PHPSESSID=finn7o2tpa9eed7sulu9l8gik2&/topic,60973.0.html
« Reply #353 on: December 29, 2011, 09:46:31 AM »
 :) here are one
« Reply #354 on: December 29, 2011, 09:48:39 AM »
 ??? trying again
this are haynes
klic for bigger pic
« Last Edit: December 29, 2011, 09:53:05 AM by strynboen »
« Reply #355 on: December 29, 2011, 09:59:07 AM »
As mentioned I agree with the rear gap. Maybe i was dreaming and there is no contention. My Clymer and several other CB750 related books clearly show the gap in rear.
So if no one steps forward to champion the gap in front idea, forget i brought it up.
I searched and couldn't find any thread to that effect.
Offline SohRon
« Reply #356 on: December 29, 2011, 10:20:13 AM »
Don't want to hijack this thread. Stryboen, your diagram clearly shows the gap being oriented to the rear (I'm assuming "vome" means "front"). Here's the same page from the English version:
Thanks.
mrjack55
« Reply #357 on: December 29, 2011, 10:58:33 AM »
Not again...  :o
When I started as a honda mechanic, circa 1969, I was assigned for the first 3 months to be the Assembler of new bikes out of their crates (it was a shop tradition, to teach you about the bikes). ALL of the Hondas came with the gaps in the front, despite what the various manuals said, straight from the factories. It was a point on the cheklist, done by the shop manager, after the assembly. I did get it wrong on a few at first, and was reprimanded, so it was always easy to remember after that.
A mechanical stress analysis will show that the forces involved in a bump incident will enter the rear stud with far less shear (i.e., strees vector enters at an angle) if the faces meet flat. In real life, the studs are so big that I doubt anyone would ever shear one off: I once changed oil on a California rider's bike (at our Illinois shop) who was on a cross-country two, two-up, and one of the nuts on the front cap was missing altogether! There was no damage, and he never noticed until I pointed it out and sold him a nut and the two washers. It was bolted flush on the back side, front one missing.
Just in case Mark has had enough of this topic, I found this bit from 09.
« Reply #358 on: December 29, 2011, 11:34:46 AM »
Not again...  :o
Thanks! At least i know i wasn't dreaming. I think there is quite a bit more, but it all revolves around what was said there.
Offline SohRon
« Reply #359 on: December 29, 2011, 12:36:07 PM »
You have to give HondaMan his due respect; he certainly was there when it all came down, and I consider his opinion to be pretty close to God speaking; but, that said, it flies in the face of all the other evidence I've found.
Evidently this is a question with no real answer. Sorry for the disruption. Carry on.
« Reply #360 on: December 29, 2011, 12:49:29 PM »
all respekt for honda mann...but hvat say kawasaki yamaha suzuki..honda cbx ......ok cbx have 4 bolts..
and sorry for off topic..norvay.... :-\
« Reply #361 on: December 29, 2011, 01:11:18 PM »
Well that's where I ended up, too. So what I do myself about this is a closely guarded secret.   ;)
In my quiet moments, I do Google searches...
Offline lordmember1969
« Reply #362 on: January 02, 2012, 11:26:31 AM »
Thank you guys :) And happy New year :) :) will put the gap in the rear :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #363 on: May 13, 2012, 06:48:21 AM »
Hi all its been a while since there been some progress on the bike:) A lot of stuff took time from the bike. Finally got some time to do the wiring. Decided to use the carburettors to test everything before I started wiring the EFI. Could not use the tank because the arms on the carbs hit the tank. So the old SS tank vent on intill the EFI goes on.
Here are some pictures  :) :) :)
One of the projects that got in the way :)
Relocated battery
DOHC exhaust did not fit but after some cutting, welding and grinding it looks allright:)
« Last Edit: May 13, 2012, 07:14:30 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #364 on: May 13, 2012, 07:37:10 AM »
For those who are interested in the oil in swingarm :)
Feed,return and ventilation under the tank/swingarm:)
You can see the tube for the ventilation in the oilfiller hole :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #365 on: May 13, 2012, 08:59:07 AM »
you have  a  long vinter in norvay...and you use the time for some great procjekts...
« Reply #366 on: May 13, 2012, 09:07:54 AM »
Thanks :) :) :) Annyone know what would bee the best fork oil. Tried 10w 40 fork oil but the forks feel to hard and the return is to slow? Annyone had the same trouble? :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Mugen_Stumpo
« Reply #367 on: May 13, 2012, 09:36:21 AM »
top notch work... wow
« Reply #368 on: May 14, 2012, 08:30:59 AM »
Thank you:) Anyone have thoughts about the fork oil?
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #369 on: May 15, 2012, 02:24:47 PM »
 Oilcooler:) :)
Did fill up the oiltank:) But was short of one hose so have to wait til tomorrow to start up :)
Holds 2 litres off oil, so hope that will be enough :)
« Last Edit: May 15, 2012, 02:29:41 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #370 on: May 15, 2012, 04:59:15 PM »
As with all oil threads, "best' is in the eyes of the beholder. 10W-30 is in many manuals. A little stiff for my taste. ATF is in many manuals. That's about 7-8w depending on the source. I like it. It also has stuff in it to make it seal and anti-foam friendly. I guess, who knows.
I'd use ATF as a starting point, and experiment from there. There are dedicated fork oils available from on line or cycle shops mostly in the dirt bike section, that vary the weight in small increments above 10, like 12, 15, etc.
Remember that in our old forks the oil plays little part in compression damping. Some, just because its there. The spring does most, like 95%, so if its too stiff its either the spring or live with it.
The oil dampens the rebound. Too much damping and the wheel won't follow rapid succession bumps. And it feels bad in the bumpies. Too much damping rebound can make the com presion side feel stiff. Imagine, the wheel goes up nicely, goes back down slowly. doesn't get fully set before it hits another bump. Compression now suffers, and the rebound is once again too slow. Com presion suffers again. You can actually suck the front end down each bump this scenario, building in more and more preload into the spring, causing it to feel stiffer and stiffer.
« Last Edit: May 15, 2012, 05:07:56 PM by MCRider »
« Reply #371 on: May 16, 2012, 05:10:29 AM »
Thank you:) The wheel does not go back fast enough so it dampens the rebound to much..
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #372 on: May 19, 2012, 01:52:34 PM »
First test ride today:) Worked out well:) Had to modify the gearshifter a bit, but other than that all was ok. Had oilpressure:) ;D Was a bit worried that the oil reservoir was a bit to small. The oil level varies a bit from full throttle to idle . But vented the tank and seems to work well  :) :) :) :) :) Are going to a rally tomorrow so will be testing further :)
Time for a beer.... Cheers  8) ;D
« Last Edit: May 21, 2012, 04:30:40 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #373 on: May 21, 2012, 04:17:24 AM »
Anyone tried to run carburettors from the CB 650 on the 750?
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #374 on: May 21, 2012, 10:48:13 AM »
that beer..breather??up behind seat..tuborg??danish dynamite
