Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 97370 times)
Offline lordmember1969
Re: Norwegian cafe
« Reply #25 on: May 13, 2010, 02:18:44 AM »
Pistons?
These came with a parts bike i bought, they are 65mm. PO said they were from a big bore kit? Anything I can use in a rebuild ? Did not come with rings but PO meant overbore Honda rings should be fine? Anyway to find out?
Thanks :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Re: Norwegian cafe
« Reply #26 on: May 13, 2010, 09:06:58 AM »
Anyone tried welding the brake bracket to the fork?  :o
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #27 on: May 13, 2010, 09:21:06 AM »
65mm is 809.7cc, commonly called a 810 or 811 kit. Not a standard Honda size, including the Honda overbores which would stop at 64mm. Yoshimura was major manufacturer of 810cc kits. Doubt they have anything left to fit.
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: Norwegian cafe
« Reply #28 on: May 13, 2010, 09:47:57 AM »
call up weisco or something, they might have some rings to fit...  i work for a piston ring manufacturer, but we don't do automotive/motorcycle rings like that, sadly
as for the welding to the fork tube, i don't know if anyone has attempted it.  i hear welding on the old aluminum can be a bit tricky
Re: Norwegian cafe
« Reply #29 on: May 13, 2010, 09:52:39 AM »
Thanks guys  :)
Will try to weld, if i f......k up i have another set of forks. And make brackets to fit the caliper :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline wannabridin
  • -Garrett
Re: Norwegian cafe
« Reply #30 on: May 13, 2010, 11:02:45 AM »
just remember to clean the fork tube as well as you can!!  inside and out, don't want anything catching on fire or you breathing in any bad fumes!!  also, make sure it's a good and penetrating weld, and don't quench!  it could become quite brittle with anything other than air cooling...
traveler
Re: Norwegian cafe
« Reply #31 on: May 13, 2010, 12:09:51 PM »
Should work fine.....why not?  If the oil is still in the tube, it will keep things cool.....if surface prep is accomplished it will work fine.  then later, when the forks are someday apart...clip off all the old brackets to clean the look up and it will be truly one-off.
~Joe
« Last Edit: May 13, 2010, 12:14:55 PM by traveler »
traveler
Re: Norwegian cafe
« Reply #32 on: May 13, 2010, 12:14:13 PM »
Pistons?
Thanks :) :)
Well, I hope you can find some rings....although they will more than likely be VERY expensive.  So, you will have to decide then if they are really worth it, or sell them off to someone who collects stuff like that and go with an 836 kit or something.
Nothing wrong with staying at 736cc and spending the money on the head and cams BTW.
~Joe
traveler
Re: Norwegian cafe
« Reply #33 on: May 13, 2010, 12:22:54 PM »
Take old " Harley" handlebar, got same diameter as the frame tubing.
Cut, weld, and grind :)
Make sure you put some smaller tubing between the pieces to act as a plug to ensure a strong weld!
~Joe
Offline wannabridin
  • -Garrett
Re: Norwegian cafe
« Reply #34 on: May 13, 2010, 12:52:06 PM »
~Joe
x2!!  also, for added strength, if needed, throw a couple plug welds onto the plugs and then add a nice transition piece as a gusset somewhere next to the newly created joint.  look good, and add strength!
and Joe, nothing wrong with staying at 736 indeed!!  except i might just have to grab a set of 4th over pistons from Z1...  that makes it something like 761?
Re: Norwegian cafe
« Reply #35 on: May 13, 2010, 01:06:48 PM »
Re: Norwegian cafe
« Reply #36 on: May 13, 2010, 01:20:03 PM »
Thanks a lot for all the advice and interest. For the welding  of the front fork a Friend who is professional will help me out.. Will try to do it this weekend, so I let you know how that turns out..
~Joe
For the frame, will follow your advise there:) Thanks
760.921   ;D
http://www.nightrider.com/biketech/calc_displacement.htm
Cool :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #37 on: May 13, 2010, 01:23:09 PM »
~Joe
Took of all the brackets exept the fender brackets, The old one for the brake already gone :) :)
« Last Edit: May 13, 2010, 01:26:53 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #38 on: May 13, 2010, 01:34:50 PM »
~Joe
Will do head and cam, but these were almost free :) :) So Will try get rings :) Any advise on a good street cam? Would like as much torque as possible :) ;D
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline MFHP
Re: Norwegian cafe
« Reply #39 on: May 13, 2010, 02:15:08 PM »
How did you calculate that? With a stroke of 63 mm this 65mm bore will make around 836cc which is the same as Wiseco. Might be worth trying if Wiseco rings fit or if the pistons can be modified on the lathe to make wiseco rings fit to them. The pistons look interesting as they seem to have a quite high CR with the high dome they have
Mike
« Last Edit: May 13, 2010, 02:22:29 PM by MFHP »
Re: Norwegian cafe
« Reply #40 on: May 13, 2010, 02:57:52 PM »
Mike
Plugged it into this calculator.
And you're right. I must have fat fingered the first go around.
« Last Edit: May 13, 2010, 03:00:00 PM by MCRider »
Offline MFHP
Re: Norwegian cafe
« Reply #41 on: May 13, 2010, 03:07:50 PM »
[/quote]
[/quote]
well, thats a V-twin page. Would explain it as well  ;D
Re: Norwegian cafe
« Reply #42 on: May 13, 2010, 03:11:29 PM »
[/quote]
[/quote]
Yeah that's the ticket, it wasn't my fault.   ;)
I tried this one too.
http://www.bgsoflex.com/displacement.html
I've tried every combo I could think of and can't duplicate my error.
Thanks for keeping me honest.
Re: Norwegian cafe
« Reply #43 on: May 16, 2010, 09:27:18 AM »
Done welding the rear. Not decided on the design on the taillight yet. But this is how it looks so far :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #44 on: May 17, 2010, 01:47:53 PM »
Cleaning up the triple trees :)
Weld up :) :)
And then some grinding :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Holdingfast
  • It's all up in the air.
Re: Norwegian cafe
« Reply #45 on: May 17, 2010, 02:15:05 PM »
great build so far! I love the way you're finding solutions to the problems encountered.
Re: Norwegian cafe
« Reply #46 on: May 17, 2010, 02:20:53 PM »
Thank you :) That is the fun part :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Zig
Re: Norwegian cafe
« Reply #47 on: May 18, 2010, 03:51:49 AM »
thought quenching of non ferrous metals made them softer?? not sure, have done repairs on copper, brass in the past but never aluminum.
Offline MFHP
Re: Norwegian cafe
« Reply #48 on: May 18, 2010, 03:57:25 AM »
Taillight setup looks great. Go with that
Mike
Offline 750
Re: Norwegian cafe
« Reply #49 on: May 18, 2010, 04:28:28 AM »
Wow, I have to say, this is one of my favorites.  Do you have or have you had it running on the EFI yet??  As far as the aluminum welding goes, this is a big deal when talking about brakes.  It really depends on the type of aluminum.  Please feel free to correct me if I'm wrong.  I 'm going off of memory, but I believe If its 50 or 60 series it is weldable.  However if it's 20 or 70 series it is not.  Most aluminum's I have worked with will take a weld and it will look vary nice.  Though, if the aluminum is not weldable it will usually stress crack right away along side of the weld.  That said, this doesn't always happen right away, it could hold for a long time and let loose at an inopportune time.  I propose for your safety and for the safety of everyone else you devise some sort of bracket instead of depending on an unknown or do some heavy research and find out the the makeup of the aluminum and know before you strike an ark weather or not it is weldable.  Just a suggestion ;D  That and about $75.00 at StarBucks will get you a cup of coffee.
