Hello all. I am new and have only worked on my goldwing.
My main ride is a 77 goldwing but just came across a project 74' CB 360 bike on Monday and then found what seemed to be one in excellent shape on Thursday when advertising request for parts for 360's locally on criagslist.
This one is a 75' cb 360. The owner turned out to be a owner of a motorcycle shop locally. It starts and runs beautifully, and since it was on the showroom floor I thought it was in good running shape.
. Ended up doing trades on extra hunting equipment I had for both bikes.
Well I titled it and got tags. drove it around for the day. I saw some oil on the left fins around the spark plug after a day of ridding. Well last night I got out after wife went to bed(perfect bike tinkering time.
). I had run the bike for a few min to see if I see a leak. well I used my fingers to wipe some oil and the head and exhaust were warm but could touch. I for some reason touched the other pipe and head. side of my finger now has a blister.
This is a good thing. It told me the left cylinder was not getting fire. Which is were the oil leak is. I pulled the left plug wire off while running and no difference. I put a test plug on it and it was firing. I pulled the new shiny plug from the bike and it was firing but coated in oil. --So no gas getting to that side. I pulled the gas line from the carb and it is getting gas. unscrewed the float drain bold and gas is coming out. mmmmm.
I figured out that the bottom tiny screw on the side was for idle later on when looked in the service manual I downloaded the other day. It was set to 2 1/2 turns out. I started unscrewing it to see what happens and about 12 turns out. the idle picked up real good. I pulled the spark plug wire on the left side and the performace dropped dramatically. I adjusted the idle down to about 1200 and purring good. I pulled the right plug wire at this point and it stayed running this time. Both sides firing good now.
It burned all the old oil out and smoked for a few min but then is was clear.
I took her out and when I came back I put it up on center stand and checking it out.
Looks like the oil was coming from the top cylinder gasket. I thought I would check the bolts because it looks like someone had the top off and casket material was used to put it back on. well I checked the front left top bolt and it started to tighten. Not putting any pressure on it. well it keeps slowly turning. the thing is stripped
. the others around it are tight.
QUESTIONS now.......
* It seems to run good but just a little bit of oil seaping out, not much on the fins. If it stays like that and very little leaking out would that be OK?
* Can I get a self tapping bolt that I could screw in from bolt store that will put new threading in it?
* I don't want to have to pull and tap the motor if I don't have too. I have never had to tap a thread before. If I have too, is the best thing the Helicoils I saw someone mention in another thread?
* Any alternative methods or options that I could look at?
