Author Topic: Can a rear hub from a '76 K be used on a '76 F?  (Read 1727 times)
Offline Holubs
« on: May 09, 2010, 07:30:14 PM »
Hi all,
I have two F1 bikes, but don't have a K model to compare the rear wheel/hub to.  Can the drum brake parts from the K hub be removed and the disk brake rotor parts from the F transferred to the K hub?  I assume that Honda would have made a common hub with different inserts for the drum or disk brake, wonder if my suspicion is true.  I also assume that the front wheel/hub on the K is the same as my F wheel/hub.
I need someone to tell me if I buy a '76 K model parts bike with mag wheels if I can transfer the mag wheels to my '76 F.
Thanks,
Holubs
Toys:
2 - 1976 CB750F1 - someday projects
2018 Mustang Ecoboost Coupe
1973 Mustang Convertible - Restoration needed
Whatever happened to the old songs, like The Duke of Earl?  Whatever happened to The fu*kin' Duke of Earl? - Randy Newman
Markcb750
Re: Can a rear hub from a '76 K be used on a '76 F?
« Reply #1 on: May 09, 2010, 07:40:16 PM »
The F models had rear disk brakes, the rear K Models all had drums.  You can swap the two but it is necessary to change the brake system, which can be a little tricky.
Lots of threads here about converting the K to a rear disk if you do a search.
mark
Offline Alan F.
« Reply #2 on: May 10, 2010, 05:40:11 AM »
Not a direct swap, spoked drum hubs were different than spoked disk brake hubs. The latter being a fairly rare part, sorry.
Cycle exchange does however have a conversion kit that will convert the drum wheel to disk brake, but it's not a stock appearing conversion.
-Alan
Offline Gregorymoto
  • SOHC Aficionado
« Reply #3 on: May 10, 2010, 06:22:14 AM »
Not as a direct swap. If you look at the 2 bikes you will see that the brakes in the rear are different.
Yep, i have issues with this sort of stuff.
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #4 on: May 10, 2010, 01:03:21 PM »
-Alan
that kit looks killer. I like drums in the back, though. I prefer them actually. crazy, huh.
but only with good front discs.
Offline Holubs
« Reply #5 on: May 13, 2010, 05:22:34 AM »
Thanks for the replies.  I had hope that the hubs would swap, that would be too easy.  Looks like I need to look for an "F" model with Lester Wheels on it.
Holubs.
Toys:
