Author Topic: jump from a car battery  (Read 2939 times)
puffpd
« on: January 30, 2006, 09:57:03 PM »
Hi,
I wanted to find out ifi can jump start my bike from a car battery?? hooking my bike with a car?
I wasnt sure if i can do this
Offline 750goes
  • it will live
Re: jump from a car battery
« Reply #1 on: January 30, 2006, 10:16:18 PM »
as long as your car has a 12V system and the bike battery is not completely dead it should be ok..
if bike battery is dead as a dodo........would not recommend as the bike battery could explode....
Offline rab1dwolf
« Reply #2 on: January 30, 2006, 11:39:12 PM »
I was told that starting the car might cause havoc (fry coils etc) with the electrics on the bike as the alternator does something or other.
anyone else hear this or anyone know one way or the other?  Didnt make much sense to me
1982 cb650sc nighthawk.  the work never stops.
« Reply #3 on: January 31, 2006, 12:01:41 AM »
Yes, it can be done.  Be absolutely certain of polarity Plus to Plus, Minus to minus.  The bike's charging system has no protection circuitry.  Applying wrong polarity can destroy rectifier diodes and melt wiring.
Batteries give off hydrogen gas.  Sparking the posts during connection can ignite this gas. Bang.
Connect the power source last.
The starter motor on a car can produce huge current spikes.  These have the potential for damaging the rectifier diodes in the bikes charging system.  However, the car's battery and the bike's battery really should damp these out before they can travel to the diodes.  Perhaps if you connected jumper clamps to terminals closer to the starter instead of at the battery itself, you might get these spikes into the bike's system.  The car's alternator is no issue.  It's power is but a fraction of what's in a fully charged car battery.
Offline oldbiker
  • I HATE RAIN
« Reply #4 on: January 31, 2006, 02:01:57 AM »
I keep a spare fully charged car battery in my workshop and if the need arises use that to start the bike or the car. Never had any problems. Naturally, if you take such precautions, the need never arises.
Offline cb650
« Reply #5 on: January 31, 2006, 02:50:40 AM »
Give the starter a rest every so often.   The car battery will last longer than the bike starter and might burn it up.   I dont have the car running either.
            Terry
Offline cadler
« Reply #6 on: January 31, 2006, 04:07:13 AM »
Yes make sure the car is not running and you should have no problems
« Reply #7 on: January 31, 2006, 06:46:08 AM »
I do this all of the time and it is not a issue. This is especially true if the car is not running. Think of it this way, the starter motor will draw or pull what it needs from the battery. It is not a "push" like you will find using a car charger with a "start"  feature. The biggest risk you will run is that the car battery will allow you to crank the Bike starter longer than a Bike battery can which can overheat the starter. 15 seconds is the total max you should crank a starter. Then give it a rest.
k4rider
« Reply #8 on: January 31, 2006, 07:57:25 AM »
Don't start the car at all.  Try the kick starter first!
Offline dusterdude
« Reply #9 on: January 31, 2006, 10:03:05 AM »
tt,you`re lookin better my man.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #10 on: January 31, 2006, 10:20:36 AM »
I just did it 2 hours ago with a spare deep cell battery from my camper.  No problems.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline n9viw
  • Floyd, '76 CB550k
« Reply #11 on: January 31, 2006, 10:32:35 AM »
I smoked the charging circuit on my bike by starting from a running car (my wife's Jeep CJ-7)- it was a bloody good thing the battery was as new as it was, I just barely made it home. Had to pitch the battery and rectifier, and had to replace about half the wiring. Thankfully, the rect going poof saved the alternator.
I've since started the bike with a car batt, but ALWAYS from a non-running car. I let the two batteries sit connected together for about 5 minutes to poke a bit of charge into the bike batt, then start the bike and let it run on both batts for a bit. Always get the bike batt on a desulfating charger as soon as possible.
Nick
'76 Honda CB550k
'73 Honda CB750k
swamprat
« Reply #12 on: January 31, 2006, 10:54:04 AM »
Have to agree with most of the posts.  I had a Suzuki Cavalcade that was jump started off the car battery more that the bike battery.  Always with the car engiine OFF.  Just my 2 cents worth.
Nobby C
« Reply #13 on: January 31, 2006, 01:48:18 PM »
I have often started various bikes from car batteries.    The trick to not frying the bikes electrics is to connect the negative terminal of the car battery to a good earth on the bike as far from the bikes battery as you can.  I usually use the rear shocks mounting bolts. This allows the frame to "absorb" a lot of the over current. The +ve terminals are connected together as normal. I have never had any problems this way, even with the car engine running.     BTW this is also the best method to use when jump starting cars with all thier electronic circuitry.    Nobby
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #14 on: January 31, 2006, 02:14:36 PM »
TT representing the HandyMan's Fractal...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
puffpd
« Reply #15 on: January 31, 2006, 04:02:08 PM »
thanks for the info guys
Offline rab1dwolf
« Reply #16 on: February 01, 2006, 02:05:43 AM »
how would you know if you toasted the starter?
I assume it would sound different when trying to crank yes?
Offline cb650
« Reply #17 on: February 01, 2006, 04:05:54 AM »
Or it dont work at all.
            Terry
