Author Topic: good weekend for some...  (Read 5274 times)
Offline turboguzzi
« on: May 11, 2010, 04:12:08 PM »
not so for others,
Riccardo bent valves on his 750....
luckily someone lent him a nice laverda 500 to do the race
Offline turboguzzi
Re: good weekend for some...
« Reply #1 on: May 11, 2010, 04:14:25 PM »
good action out there.
a new class called guzzi cup is proving popular
three sohc riders battling it out at the bottom
Offline turboguzzi
« Reply #2 on: May 11, 2010, 04:28:12 PM »
my own toy behaved well, another 4th place, missed the podium by just a couple of seconds after a race long battle with a friend, good fun.
We had some UK guys, John Cronshaw was here as well as Bob Dixon with his 500 Laverda,
we have a long break now till next race in july, time to work on my airbox project, fit an RD350 fork with cartridges and maybe a 650 sump and primary chain tensioner. should keep me busy.
TG
« Reply #3 on: May 11, 2010, 05:37:01 PM »
Tough luck Riccardo, what was the cause of your problem? Or should I ask.  ::)
TG, didn't you tell me there was some issue with those RD forks?
« Reply #4 on: May 11, 2010, 07:43:30 PM »
I 'm interested in that too.
Offline turboguzzi
« Reply #5 on: May 11, 2010, 11:38:50 PM »
he told me he might have over revved, he might have to tear the engine appart to know
the only issue with tht RD forks was lack of time....
I dont like the fact that it has only through holes for the axle in the legs, no means of clamping on the axle,
but other than that they are a few kilos lighter than the stock ones and have double teflon bushings,
so should be an improvement
TG
  • Moderator
« Reply #6 on: May 12, 2010, 12:14:23 AM »
Laverda  8) it helps when you mix in the right circles ;D ;D ;D good lad Riccy ;)
Sam. :)
Offline livefast_dieold
« Reply #7 on: May 12, 2010, 12:50:27 AM »
Last weekend I've learnt to always double check valve-piston clearance after cam timing! A missed gear and ex valves high five pistons, luckily I only bent them so not a lot of money to repair the engine (I'm thinking on cyclex super flow valves, are they ok? plus the aluminium valve retainer)
A friend of Piero Laverda lent us his Formula 500, and the guy in the first picture crash it just after I ended my turn. Not a lot of damage even it this case, but not a nice thing to do. He says that he braked on some dirty stuff and the bike suddendly fell down...
Not a great weekend but I've learned a lot on how building a race bike, how to drive it and how to choose an endurance pilot among your friends  ;D
« Reply #8 on: May 12, 2010, 04:19:25 AM »
a pics of the bike befora damages:
Offline turboguzzi
« Reply #9 on: May 12, 2010, 05:03:19 AM »
now, thinking of it, Howell had a bizarre valve bending story due to material coming off the fiberglass tank and sticking to the guides.... inlets though.
check if they are free in any case.
to do a proper job of checking valve clearance mount just one set with weak springs you can push by hand
TG
  • Moderator
« Reply #10 on: May 12, 2010, 05:40:52 AM »
My fiberglass tank sprung a leak within 15 minutes of putting the fuel in. >:(
Sam. :(
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #11 on: May 12, 2010, 11:32:52 AM »
TG
Good result TG.
Why do you have your seat so high ?
Is it allowed to have a airbox on a classic racer ?
You meet the nicest people on a Honda
Offline Howell
« Reply #12 on: May 12, 2010, 11:39:41 AM »
TG
Indeed , material from the fibreglass tank was the cause of our inlet valve problems.
Don't use a fibreglass tank with modern or race fuels !!!!!!
But we had enough valve to piston clearance.
Offline turboguzzi
« Reply #13 on: May 12, 2010, 11:49:27 AM »
TG
Good result TG.
Thanks howell, I think I can now say that it took three years and some 20 races to really feel good on the bike, my first race  in this track i was doing 1:37's, I was down to 1:29'-1:28's all of last race. nice satisfaction.
Seat? I am 1.90m tall, need a bit of room for my legs to bend :)
Nothing in our rulebook says that you cant put an airbox and those bikes came with one stock. not that the one i am building is going to like like the stock one...
Offline Howell
« Reply #14 on: May 12, 2010, 11:52:01 AM »
TG
Using a RD350 YPVS fork is a big improvement , but not only the fork , very important is also the right springs , oil viscosity and oillevel and the right setup of the dampervalves.
Our fork is working very well , but the setup is done by a skilled mechanic from YSS shocks Europe.
Offline Joksa
« Reply #15 on: August 05, 2010, 04:07:10 AM »
Do you have any detailed pictures? I am considering a fork upgrade for my CB500K0, but I don't have any rule restrictions (road bike, maybe occasional track day),
but I would like maintain the bike as "period correct" as feasible. I already have 18" GPZ305 (or optionally 19" 440LTD) front wheel so I might just swap EX500 (GPZ500S) 36mm forks and try to disguise the triple trees/yokes as much as possible and use 36mm telefix clip-ons I have waiting. Retrofitting cartridge internals also sounds very appealing...
« Last Edit: August 05, 2010, 02:40:24 PM by Joksa »
Offline turboguzzi
« Reply #16 on: August 05, 2010, 01:25:58 PM »
detailed pictures of what exactly? If you are not limited by racing rules to a 35mm fork, then 36 will still look pretty period IMHO and be more rigid.
TG
Offline Joksa
« Reply #17 on: August 14, 2010, 04:32:34 AM »
I was mainly interested on the RD350 front axle setup and also brakes. But I probably go GPZ route and use also brakes from Kawa. (Hmm... I also waiting for set of KZ650 mikunis, looks like my CB is slowly turning into a Kawasaki)
I have been searching info about retrofitting cartridges to 35-39mm forks but really haven't found anything usefully yet. Maybe I just have buy a set of cbr600f2('94 only) or f3 41mm cartridge forks and see how the internals look like.
  • Moderator
« Reply #18 on: August 18, 2010, 01:07:14 AM »
Offline turboguzzi
« Reply #19 on: August 23, 2010, 03:22:36 PM »
Know this one TG?
http://www.motocicliveloci.it/images/pezzipregiati/honda3.JPG
Sam. ;)
yep, massimo, the shop owner is a good friend.
it's a pretty stock bike other than the Menani tank and seat. sat on it and the tank is not that comfy, but sure good looking.
TG
