My F was happier with an 18 tooth front sprocket, the top two gears are lower if I remember correctly. The F cam is a good choice, mine seemed torquey but I had too much fun revving it and tagged a valve using stock k springs. The 78F front sprocket is 10mm further out, it can be used by matching the rear cush drive.
