The pins sit down in holes that are drilled into the end of the shift drum. In order to be deflected that much, the pins are bent or the holes are trashed.
mystic_1
Edit to add: On the drum I just measured, four of the holes are 5mm deep, and the fifth is 9mm deep.
mystic_1
