Author Topic: How important is the air filter restriction on the carbs?  (Read 922 times)
Offline Ved
« on: May 16, 2010, 04:00:11 PM »
I'm working on a 1977 CB750A and the air filter box is missing so I ordered some POD cone type air filters that seem to have little to no air restriction at all. I literally had to tape off 80% of the surface area of the air filter surface area to create enough vacuum so it would pull fuel, and run. I can get it to start quite easily when choked with no problem, and it idles perfectly, but when I throttle her up to around half throttle it dies out like its starving for fuel. I checked each bowl and the floats are doing their job. Filling up nicely, and shutting off, no leaks. Upper and lower jets have been meticulously cleaned and are flowing fine. Pilot screws are at the factory setting of 1 turn out. I can't seem to find the sweet spot on the air restriction so it winds out without dieing.
Any thoughts?
~Ved
Your a good friend, but if the zombies ever chase us... I'm tripping you...
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
Re: How important is the air filter restriction on the carbs?
« Reply #1 on: May 16, 2010, 04:23:57 PM »
Your going to have to rejet and possibly move the needle up or down. Theres a lot of threads on the forum about it. Its a real pain rthat I'm in the middle of going through right now. The best thing you can do is oull the bike until it starts to cut out, then pull the clutch in, hit the kill switch, and coast to your shop and take your plugs out.
If they are white its lean and if they are super dark and sooty/wet its too rich.
Its hard to be wrong when you know nothing!
Offline Old Scrambler
« Reply #2 on: May 16, 2010, 05:00:31 PM »
I would strongly advise to get the stock air-box.  The A-carbs are smaller than other models and very touchy to run smoothly at road-speed with the auto.  Pods are for go........not cruise!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Ved
« Reply #3 on: May 16, 2010, 05:05:30 PM »
Thanx for the quick response guys. I called a local motorcycle junker/collector here and he has an air box for me..10 bux.  I just need to get a filter for it he said.
Also, on a side note... Could the accelerator pump be part of the problem too? When I cleaned the carbs all I did were the jets and the float needle, but  never did check the darn acc pump on the carb. The lower jets were completely clogged, but upper jets weren't so bad. I bet that acc pump on the carb has a clogged hole as well.
« Reply #4 on: May 16, 2010, 05:18:49 PM »
I think that solenoid you mentioned on another thread is for the accel pump on A models..
Edit: just looked at the manual; think I was mistaken. Sorry!
« Last Edit: May 16, 2010, 05:27:34 PM by scottly »
Offline Ved
« Reply #5 on: May 16, 2010, 05:38:22 PM »
The solenoid valve does not connect to the acc pump.
Throttle opener solenoid
Throttle Opener to solenoid valve location
Accelerator pump.
