Remember why you bought a Honda to start with.
I remember, and it wasn't because I like oil dribbling down my cylinder fins or spraying onto the side covers. This seems to be a common issue with Honda SOHC fours. My 500 was leak free for almost 4,000 miles. Then it started weeping oil from the O ring area between head and cylinder on the left side. Recently, it's started on the right as well. Not bad enough to make a mess, but bad enough to annoy me. Re-torqueing the head stopped it for a while, but it returned. When the riding season is done, I'll likely pull it down to have the head and block surfaced. And I'm thinking of finding some replacement O rings made of Viton, and maybe even a slightly thicker section so they get compressed tighter.
Stu
Have you considered teflon orings with their higher heat withstand specs.?
It's pretty well known that the oil passage orings get hard and brittle with heat (they aren't far from the combustion chamber), then leak. I don't believe head and deck resurfacing is going to fix that.
A compression seal loss is an "almost never" occurrence. So, don't be blaming the head gasket (if anybody is thinking that).
I've had the weepy head syndrome on my 550's for 20 years. I just wipe it off once a week (or month). Never been bad enough to tear the engine apart, as it just runs too good. Someday, I'll try the teflon orings.
