Prying, tapping with a rubber mallet is the only way I know. Take your time, tap and/or pry a little from different directions. Be carefull, as you said the fins break easily. I don't know the 550 engine, but make real sure you don't have another bolt in a recess some place not easily seen. These gaskets get really stuck on with time. Once you do get it apart, some spray on gasket remover makes clean up a whole lot easier.
