Author Topic: Carb Leak between #2 and #1 - broken "fuel pipe" (plastic fuel connection)  (Read 8730 times)
Offline kerryb
  • Not a very
SENT...the nice lady at the post office said you should look for it on Thursday.
She didn't say it would arrive on Thursday, just that you could look for it.
glad I could help, kerry.
Offline Kevin400F
I use 5.8mm ID x 1.9mm cross-section O-rings.
Offline midnightrider
  • Out of the SOHC4 world for a while...
You're a saint, Kerry.  Thanks.
1972 CB350 Four - "The Green Hornet"
http://forums.sohc4.net/index.php?topic=84975.0
I love being alive and I will be the best man I possibly can; I will take love wherever I find it and offer it to everyone who will take it... seek knowledge from those wiser and teach those who wish to learn from me.
-- Duane Allman's epitaph
Awesome job, Kerry!  The fuel pipe you made works great!
Thank you so much; you're a lifesaver.
Offline BlitzAttack
Re: Carb Leak between #2 and #1 - broken "fuel pipe" (plastic fuel connection)
« Reply #29 on: September 02, 2014, 02:22:15 PM »
Well looks like I have two of these that are broken just like yours. Anybody have any leads on where you can find these? I dont have access to a mill so I cant make anymore.
Thanks
Offline harisuluv
« Reply #30 on: September 02, 2014, 02:31:52 PM »
I have been making them for awhile.  I sell them for $40 shipped a pair.
Offline BlitzAttack
« Reply #31 on: September 02, 2014, 03:23:04 PM »
PM sent
Thanks
Offline saha6818
Bump! I'm rebuilding a CB350F for my girlfriend, and one of these little dongles is broken. I made another out of a vinyl spacer, and it holds, but I'm concerned that the gas will eventually eat the vinyl. I messaged harisuluv with no response after a few days (time is tight). Does anyone have a source? eBay doesn't seem to do much volume with these. There's a set listed now, and I'll probably move on that soon. Does anyone know a source? The many other parts I've needed were a breeze finding.
THANKS!
Offline harisuluv
Don't see a PM, sure you sent it?  I don't really make them anymore, but I have a few spare OEM ones.
Offline Black Betty
Does anyone still make or have extras of these fuel pipes by chance?  :-\ One of mine just snapped in half cause it was so dry rotted. Need one but would love to replace all.
Offline kerryb
  • Not a very
Did you check with harrisulov?  If he doesn't have one I could make some more.  Let me know.
Offline przjohn
That is good to know as last time I had to pay the Ebay ransom for a few.
Offline tycmitchell
I could use a set.  One of mine seemed to be leaking and I managed to easily snap that sucker in half.  Maybe a good cleaning and rebuild is a better idea.  Might have to contact harisulov.  My carbs are pretty rough.
Sent from my HTCONE using Tapatalk
« Last Edit: August 29, 2015, 11:13:43 AM by tycmitchell »
Offline TheSkids
Another CB400F with a broken Fuel Pipe. The PO snapped it and tried fixing with JB Weld and then glued the pieces into the carbs 🤦‍♂️. Any leads anyone? I know it’s a long shot since this was 10 years ago.
Offline TheSkids
Actually i just read that PETG is gas and chemical resistant. I guess i will try 3D printing a new fuel pipe until 4into1 gets more aluminum ones in stock.
You may find that the "odd" metric size is an exact imperial size, worth cross checking
Offline TheSkids
I did a quick design and print and it appears to work. Fits snug. I had to print it horizontally to maximize the strength of the piece, so its not the prettiest. If it holds up well, I will post the .STL file so anyone else with this problem can print their own. Obviously the best solution will be to buy aluminum fittings when they get back in stock on 4into1.com
Offline WhyNot2
  • I'm finally an
dayyyyyyyum.......you know I have a leak about that same spot on my 350F.
carbs are coming off again for umpteenth time.
