Author Topic: intermittant # 3 & #4 running?  (Read 720 times)
birdy
« on: May 19, 2010, 03:39:27 AM »
Ok- I start her up and only runs on#1 & #2. Hold throttle to keep running (I've already turned throttle screw up), rev her up and finally #3 & #4 kick in.
Go round the block engine revs nicely until after a slow 30/40 mph cruise - I come to lights and it's back to #1 & #2 only again. Limp home on 2 cylinders.
Not the coils due to pairing order - can it be fuel to carbs, but why only now and again?
Offline donny
Re: intermittant # 3 & #4 running?
« Reply #1 on: May 19, 2010, 04:11:49 AM »
yes....I would look at fuel issue,  since 3-4 share a fuel line.. ..
       1 )  float levels ? ?
       2)   semi plugged fuel line to 3-4 ?
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline tlbranth
« Reply #2 on: May 19, 2010, 09:23:15 AM »
Clean the petcock and try removing line filters if you have them.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline my78k
« Reply #3 on: May 19, 2010, 09:30:33 AM »
What bike? Is there 2 separate fuel lines or shared? When were the idle jets cleaned?
Dennis
« Reply #4 on: May 19, 2010, 09:42:37 AM »
What do the spark plug deposits look like?
When was last tuneup check list completed?
What is the cleaning history of he carbs?
