Author Topic: CB750 Turn Signal Flasher  (Read 5999 times)
Offline spiritof67
« on: May 25, 2010, 04:50:05 PM »
I know, it's a mundane subject. But does anyone (or has anyone) have a source or crosslisting for the Signal Stat turn signal relay which fits the SOHC Cb750? The OEM replacement is $32. Any help here with the same item but cheaper? There surely has to be some other motorcycle or vehicle which uses a Signal Stat 142 turn signal flasher which isn't the same price as 10 gallons of gas.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
Re: CB750 Turn Signal Flasher
« Reply #1 on: May 25, 2010, 04:55:29 PM »
AUTOZONE has them. Check out the link.
http://forums.sohc4.net/index.php?topic=10290.0
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline spiritof67
« Reply #2 on: May 25, 2010, 05:46:22 PM »
I'm looking for an exact replacement size-wise for the Signal Stat 142 though; what I've seen is a nice flasher but not a real replacement. Thanks for the help - does anyone have a source for the 142 or exact replacement?
