so confussed right now heeeeelp .
new to this blog but me pal told me this is a good spot soooooo thanks for listeninghere it goes .
start from the nearest beginning ,
bike stopped running. on the highway after we came to a light . was running good . just stopped wouldn't kick through
then waited about 1 hour ... could kick it through started with a terrible sound
maybe from the front maybe from the bottom hard to tell .. slapping..grinding yuck ..sounded like a cam chain tensioner stopped doing its job or a drive chain fell off , i dont really know..
so truck it home.
Drained the oil in hopes of a surprise nothing .
flipped er upside down look inside the bottom all chains look good all stuff moving that i can see through the oil pan fine .
look in the top .. all looks good cam chain fine ... . did a valve ajusment ..theres great compression ...theres spark ... clutch is fine took it apart
okay kick er through feels good . ....
THEN as soon as i put OIL in i cant kick it . well i can but i got jump on it two feet.
SOMETHING IS WRONG .
all start with this question one . all save the other 2 questions .
sooo then we look into the oil pump maybe there is a blockage air seal , the oil pump looks fine .
I dont know . anybody have this problem .
is it time to just pull the motor and start again ? i hope not .
