Author Topic: Any Goldwing riders out there ?  (Read 3788 times)
Offline greenjeans
  • 1972 CB750K2
« on: May 27, 2010, 11:58:12 AM »
A guy I work with is trying to get me to buy a 1980 Goldwing.   Everything is there.   Looks to be a pretty nice find.
He wants $500 for it.  Supposedly it does run.   Photos look clean.   A closer inspection will tell the tale.
Anybody have anything I should know about these ?    Any info or links greatly appreciated.    Probably not the most collectible, but it
might be nice for some long cross country rides.
Offline kirkn
Re: Any Goldwing riders out there ?
« Reply #1 on: May 27, 2010, 12:12:17 PM »
Great bikes, either in full-dress, or naked guise.
Here's a great site for the 'naked' folks:  :)  http://www.ngwclub.com/forum/index.php
Offline kck3
« Reply #2 on: May 27, 2010, 01:05:41 PM »
I like the naked wings.  Prob will pick one of those up soon-a 70's model I hope.
Offline 78 k550
« Reply #3 on: May 28, 2010, 05:47:47 PM »
first year of the 1100's. what is it standard, interstate, aspencade?
if it runs it is worth it.
I like them naked. I have the fist and last year for the naked.
75 and 84.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 6adan
« Reply #4 on: May 30, 2010, 06:34:08 AM »
Great bikes, the link posted is a great place for info on them like here for SOHC4.I have two running now a 79 & 81 and am redoing a 75. First thing you need to do is change the timing belts.I just changed the heads on a friends GL1000 because the belts broke.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Johnie
« Reply #5 on: May 30, 2010, 07:42:44 AM »
The older Wings had trouble with the stator. To fix it you had to remove the motor from the frame. I am not 100% sure if that was back to 1980, but I believe the early to mid 80's bikes were affected. Do a search and maybe you can find out for sure. $500 sounds like a nice price if it runs.
Try www.gwrra.org There is a guy on this board named Stu that is a great Wing mechanic from the past and worked on the old stuff. I hope he reads this post as he will have the answer.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Johnie
« Reply #6 on: June 02, 2010, 04:30:20 AM »
This is the wing guy to contact on this board: chickenman_26
Very good on the Wings.
Oshkosh, WI  USA
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #7 on: June 02, 2010, 05:53:42 AM »
Greenjeans,
You could be getting a steal, or you could be buying a bushel basket full of expensive problems. Closer inspection won't necessarily help you, unless you know what you're looking for and how to find it. Talk to me.
Stu
MCN DTF
Offline bluefield dan
« Reply #8 on: June 08, 2010, 03:46:44 PM »
BUY IT! BUY IT! BUY IT! I've been riding my '77 GL for 17 years or so, virtually trouble free. It truly is the most reliable machine i've ever owned. Even as a parts bike it's worth 500 bucks.
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #9 on: June 10, 2010, 11:40:18 AM »
we bought my cousin's '78 GL1000 for $800 with the carbs in a box... buy it.
they are a different animal. more like working on a car to me...
if you do, definately check out the NGW site. im on there too. great tech articles. timing belts aren't that bad either. the site helped. cool thing is a lot of the parts (timing belts, thermostat, cap, etc) can be found at NAPA for cheap... timing belts weren't much more than $15 and the thermostat was the same one as in every Chevy truck for 20 years...
++1 from me
« Last Edit: June 11, 2010, 06:06:43 AM by 75cb550 (kyle) »
Offline edbikerii
    • Gallery
« Reply #10 on: June 10, 2010, 07:00:43 PM »
That was on the 1200s, and only when the connectors were allowed to get all corroded and short out.  Then the heat would burn out the stators.  Enthusiasts simply remove the connectors, and solder/shrink wrap the wires together to avoid the problem indefinitely.  I've only got about 42K on mine, but the stator connector melted on me last year.  I was lucky enough to smell the plastic connector melting/burning before it took out the stator.
Also, those who are not as lucky can fit a Chevy car alternator using a kit known as the "poorboy kit" (google it).
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
