Author Topic: Steering Damper for CR 750  (Read 2717 times)
Offline chris
« on: May 31, 2010, 04:51:26 AM »
Can anyone recommend a steering damper for CR750 dont want one of those shiny overpriced Ohlins but something a bit more reasonabaly priced and more suited to the era of the bike
  • Moderator
Re: Steering Damper for CR 750
« Reply #1 on: May 31, 2010, 07:37:03 AM »
Ask Simon (lordmoonpie) the factory ones were fitted to quite a few street bikes in the CL/SL models.
Sam. ;)
  • Moderator
« Reply #2 on: May 31, 2010, 07:45:48 AM »
Offline H2Eric
« Reply #3 on: June 01, 2010, 02:10:54 AM »
NOS CL77 steering dampers appear on fleabay occasionally, but the going rate appears to be about $300. Ouch! However, Simon (Lordmoonpie) sells a neat little job (see pic) for a fraction of that which will fit the bill nicely.
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline Old Scrambler
« Reply #4 on: June 18, 2010, 10:05:58 AM »
If your application is for the track, I'd go with something new like the unit offered by Simon..........If you want original appearance, I have used units for $50 plus shipping.  They are getting harder to find in reasonable condition. You will need to fashion a mount from the lower tree to either the frame or the top of the motor.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline lordmoonpie
    • Moonpie
« Reply #5 on: June 18, 2010, 12:04:55 PM »
Chris - as Eric says I can do a modern "old style" non adjustable damper exactly as per the photo and similar to the CL77 variety. PM me if you want details - nowhere near Ohlins prices and they work very nicely indeed!  ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
  • Moderator
« Reply #6 on: June 21, 2010, 08:30:11 AM »
Dennis, will you save me a good one and get it to Mike in Boston for when I'm there in August.
Sam. ;)
« Reply #7 on: June 30, 2010, 01:32:26 PM »
Sam..........just saw your note...........I'll look through my stash to send to Mike...........I'll check to be sure it has some even dampening in the middle-range where it is needed.  More in a day or two.........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
  • Moderator
« Reply #8 on: July 01, 2010, 06:06:34 AM »
Cheers Dennis.
Sam. ;)
