Author Topic: WHAT GAUGE WIRE is standard for the CB750 K4 wiring harness?  (Read 8833 times)
Offline Bob750
  • I guess I better fix this thing and ride since I'm now an
  • Climb out of your cage....... Ride a motorcycle!
I need to order some wire connectors, and I'd like to know what size wire the bike uses, ya know?
{Search doesn't seem to know that I'm not looking for info on the gauges in the instrument cluster, or how to gauge distance or how many people misspell gouge...}
Mine: 1974 CB750 K4
Hers: 1964 Dream 305
Offline Spanner 1
Re: WHAT GAUGE WIRE is standard for the CB750 K4 wiring harness?
« Reply #1 on: May 31, 2010, 09:17:16 PM »
The stock Honda wiring is in mm sqd........ i.e. it's metric not U.S. 'gauge'... but for all practical uses its 18 gauge stranded wire in the loom....
Offline Bodi
« Reply #2 on: June 01, 2010, 06:13:08 AM »
The wiring is 1 sq. mm area, the metric way of measuring. This is just slightly smaller than 17 AWG wire, which is basically not made. So 18 AWG is a bit smaller and 16 AWG is a bit bigger. I would use 16 for the high current wires (all blacks, red, and the ignition coil, alternator, rectifier, and regulator wires) and 18 for the rest. 14 AWG would be good for the red/white wire from battery to fuse block.
