Author Topic: CB750 k1 forks  (Read 1041 times)
Offline MarkC71
CB750 k1 forks
« on: June 02, 2010, 06:59:14 PM »
Hey all,
I'm new here and to the cb world. My friend and I just picked up a '71 750 that runs but needs a little lovin. The previous owner had put on +4 forks. I really want to return it back to original, but cannot find anything on ebay or craigslist for a k1. I was wondering whether forks from any other years would fit on my K1. And if they don't bolt right up how hard is it to retro fit them.
Thanks in advance for the help,
Mark
1971 CB 750 K1 on its way to cafe excellence.....slowly
Re: CB750 k1 forks
« Reply #1 on: June 02, 2010, 07:08:23 PM »
Scroll down the page, cycle x has them for $149.
http://www.cyclexchange.net/Cycle%20X%20Exclusive.htm
Online scottly
Re: CB750 k1 forks
« Reply #2 on: June 02, 2010, 08:23:47 PM »
The main difference that I am aware of between the K1 forks and later models is the mounting of the caliper to the fork leg. I have been told that the change was some where around K3? I know the caliper bracket from a K1 will not bolt to a K7 fork leg.
Re: CB750 k1 forks
« Reply #3 on: June 02, 2010, 08:48:08 PM »
 You really should post your location, help may be nearby..
 I am not sure that cycle X has the early ones.. they are different than k3
 Yours can be shortened by anyone that knows how to run a lathe and is carefull..  get a price first tho..
I have done quite a few..
« Last Edit: June 02, 2010, 08:50:27 PM by 754 »
Offline fasturd
Re: CB750 k1 forks
« Reply #4 on: June 02, 2010, 09:09:36 PM »
CAll or write cycle x they will know its just the fork tubes you need not the legs.
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline fasturd
Re: CB750 k1 forks
« Reply #5 on: June 02, 2010, 09:11:33 PM »
Forks by frank can get you new tubes too. Maybe forking by frank google it...
Offline faux fiddy
  • bike in a box
Re: CB750 k1 forks
« Reply #6 on: June 02, 2010, 09:28:30 PM »
Freebies in Seattle. Not sure of the model. Might be a good deal for you.
http://seattle.craigslist.org/tac/mcy/1765953752.html
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
srook
Re: CB750 k1 forks
« Reply #7 on: June 03, 2010, 05:32:20 AM »
The K1 tubes are different than the ones available from CycleX.  The K0 - K1 forks are completely different than the later ones internally and externally.  Forking by Frank has the correct tubes.  http://www.frankmain.qpg.com/
Scott
