Author Topic: Alternatives to Carillo Rods?  (Read 6628 times)
Offline MaaseyRacer
    • Fuelist
« on: June 05, 2010, 03:52:19 pm »
What are some Alternatives to Carillo rods?  I have seen Robinson Engineering in the UK, can do 400F rods, but the exchange on the dollar is not worth it right now.
My primary objection to Carillo is price.  I have started making the rounds around the various car rod manufacturers to see if they offer 400F rods, but it seems that they are all a custom order deal.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline Big Jay
    • CBRzone
Re: Alternatives to Carillo Rods?
« Reply #1 on: June 05, 2010, 10:58:49 pm »
Carrillos for the 400 are custom at $1295 a set.
Online scottly
« Reply #2 on: June 05, 2010, 11:02:50 pm »
Do you offer a lower cost 400 rod, Big Jay?
Offline Inigo Montoya
« Reply #3 on: June 05, 2010, 11:12:52 pm »
I really have a hard time seeing a price for 4 little rods being over 1200.
If I could find rods from a cbr600 or something, yeah.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #4 on: June 06, 2010, 04:25:24 am »
After having bought a set for my CB750/836 and comparing them to stock - I was impressed and started appreciating why their cost was so high. First, they are special. The stock K0~K8 series rod bolts get tightened to 14 lbs. The Carillos get tightened until the bolt is stretched to a specific length, mine took 43/44 foot lbs! The carton had 317 stamped onto the end and I had no clue as to what that was until I open each of the 4 boxes inside - each had 317 printed too. This was 317 grams, what is amazing is that all 4 (with their special wave bolts) were within .3 gram (3/10's of 1 gram) of each other. Here are photos of 2 different C-rods and then the fat, heavy stocker at 355 grams. There was more that 2.0 grams difference in the 4 stockers when compared to each other. The precise, exact wrist pins varied more in weights than did the entire C-rods.
The question you'd have to ask yourself is whether you need them. Are the other components going to support the added rpm? Are you doing extreme porting, adding cam lift and timing, springs, and valve work to change the output design of that engine to the point the expense is justified? The CB750 needs them if the engine is going to exceed stock rpm levels. The stockers won't live in the 10,000 range for long. To get the 750 to go there requires a lot of work/expense to add porting along with components that will allow it to make use of the added rpm. If the additional rpm and output of any Honda isn't going to change, then the stock rods have alway proved adequate. For me, it was absolutely required - I would definitely lose a rod and destroy a big investment, then run the risk of dumping 3 quarts of oil in front of my rear tire at speed in a corner. I ride in the mountains and curves are an everyday privalage.
Works of art in my opinion, too bad they can't be seen. They are the best piece of "bling" I've installed on this old Honda.... Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline crazypj
  • I'm brill, me
« Reply #5 on: June 06, 2010, 06:06:48 am »
 The exchange rate is about as good as it gets, I keep a pretty close eye on it
( I'm still paying a mortgage in Britain so I send cash every month)
 The only time it was better was Jan 2009
 What do you intend to do that you need Carrillo's?
PJ
Offline MaaseyRacer
    • Fuelist
« Reply #6 on: June 06, 2010, 09:48:48 am »
My intentions in the near future are to use the Spare 1976 400F engine I have to install the Web #3 grind cam (stage 2) and the RD valve springs that I acquired for crazy cheap.  Also I scored big on a set of CR 26 Carbs from a forum member (i had what he needed, he had these carbs).  Also I will be purchasing 54.5 mm pistons, probably doing some porting on the head.
Because the Web #3 grind cam makes power to 12k I will want to upgrade the rods.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #7 on: June 06, 2010, 09:49:50 am »
Talk to these guys. http://www.ttr400.com/  Falicon Knife Edge rods are less expensive, I believe.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline MattFreeman
  • What Have I Done?
« Reply #8 on: June 06, 2010, 10:17:50 am »
I picked up a set of reconditioned and balanced rods (ed. and shot blasted) for my 750, hoping they would be an improvement over stock. I don't know if they are but maybe some one who knows will interject on the subject, giving you another option.
« Last Edit: June 06, 2010, 03:03:15 pm by MattFreeman »
« Reply #9 on: June 06, 2010, 11:03:15 am »
Another option might be to shot peen the honda rods.
Offline MaaseyRacer
    • Fuelist
« Reply #10 on: June 06, 2010, 01:05:26 pm »
I am interested in looking into this.  Does anyone have any recommendation of shops that do this?  I am Northern California, but I am not opposed to shipping rods in the US.
I am also going to give Falicon a call.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #11 on: June 07, 2010, 06:50:27 am »
shoot MReick a PM.  he can let you know how much it costs to do this, as he has the capabilities to do this i believe.  also, if you're going to pay to have them peened, you might as well balance the stockers too.  along with the crank, then you'll have a smooth reciprocating assembly, which will aid in the overall performance and driveability of the motor.
Offline Doctor_D
« Reply #12 on: June 07, 2010, 07:01:46 am »
I polished, shotpeened, cryo treated, and balanced the stock assembly.  I also used stronger 77-78 750F rod bolts.  That's about all you can do to a stock rod.
Haven't run them yet, so keeping my fingers crossed.
Take care,
David
1978 CX500
1971 Norton Commando
Offline wannabridin
  • -Garrett
« Reply #13 on: June 07, 2010, 07:10:54 am »
this is about everything i've heard you can do to the stockers, but it does make a good difference with those on a budget!  you can do all this and balance your stock crank for less than the cost of a set of carillos...
Offline MaaseyRacer
    • Fuelist
« Reply #14 on: June 07, 2010, 01:48:10 pm »
I just spoke with Falicon Rods, they are cheaper than Carillo, but I would have to order several sets. Not sure I want that many.  Group buy maybe?
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
Offline wannabridin
  • -Garrett
« Reply #15 on: June 07, 2010, 01:53:08 pm »
did they give you a price per set on the minimum quantity?
Offline MaaseyRacer
    • Fuelist
« Reply #16 on: June 07, 2010, 05:05:15 pm »
I have a meeting set up with the owner to try and negotiate a lower price if we can get 12 sets (48 rods).  PM me if you are interested in the rods I will give further details as I am still talking to other rod makers.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
  • Be careful you might get a
« Reply #17 on: June 07, 2010, 06:31:48 pm »
I might get in on the group buy of rods if the price is right.
« Reply #18 on: June 07, 2010, 11:14:53 pm »
Good luck.. IMO.. I think you would be doing well to get 4 or 5 ordering..
Offline MaaseyRacer
    • Fuelist
« Reply #19 on: June 07, 2010, 11:29:34 pm »
I have five people who have sent me messages right now who are very interested, plus myself.  If you would like to try and get in on a group buy and see if we can make this happen please send me a private message.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
« Reply #20 on: June 07, 2010, 11:40:36 pm »
 Looks good if you got that many people..
 I dont have any 400;s  I got in on a 750 rod buy, but sadly have not gotten to use them yet..
Offline wannabridin
  • -Garrett
« Reply #21 on: June 08, 2010, 10:21:21 am »
are these for the 400's or the 750's?  i guess i confused myself here...
Offline MaaseyRacer
    • Fuelist
« Reply #22 on: June 08, 2010, 11:44:18 am »
Alright I have been talking with the guys at Crower Rods.  I have used Crower rods in the past in a honda civic and they make a great product.  This is also original Crower, not family members who have broken off to form their own companies.  When asking the rep about 50-70 HP CB400Fs he laughed and said he mostly deals with 600+HP Busa's.
Sets of Crower rods for $700 ($175 per rod). Quantity seems to be the issue, orders will have to be minimum or 12 sets.  Once the order is submitted they should take 6-8 weeks for delivery.
This is less than half the price of the MSRP for Carillo Rods.
email me if interested.
Eric
ericmaas@gmail.com
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
« Reply #23 on: June 08, 2010, 02:08:17 pm »
FYI - My 750 new Crower rods weigh in at 50gm more than my new Carillos. The stock rod weight is in between them. Perhaps you might want to inquire about that aspect if you haven't done so. I'd like to think an order of 12 sets of Carillos might bring the price down.
Offline MaaseyRacer
    • Fuelist
« Reply #24 on: June 08, 2010, 03:31:42 pm »
I called Carillo first.  The cheapest I can get them without ordering $35,000 worth of product per year is $1100 per set.
As far as the weight is concerned my guy at Crower claims that they will model the rod for a 315-320 gram weigh in CAD prior to making them.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
