Author Topic: where to get a CB500 rear tire rim?  (Read 1763 times)
Offline westondc
  • Wes Mantooth
« on: June 07, 2010, 02:45:56 PM »
well, while on my recent motorcycle trip i noticed a wear spot on the tread that was getting larger and larger. put the bike on the center stand and spun the rear tire. noticed that the rear rim was bent pretty bad. no point in putting on a new tire and wearing that down. so my question is: where might i be able to find a NOS rear rim for a 72 CB500? i figured i would use the same wheel center and maybe some replacement spokes. thanks
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline WFO
  • Will work for powerbands
« Last Edit: June 07, 2010, 03:04:26 PM by WFO »
82 cb650 sc nighthawk - 78 kz 650 b
Offline haill
Re: where to get a CB500 rear tire rim?
« Reply #2 on: June 07, 2010, 04:30:23 PM »
david silver spares
Offline tlbranth
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #4 on: June 07, 2010, 05:54:01 PM »
Stock rear rim is an 18", has 40 holes, and a 1.85" tire bead width.
I think any 500/550 will fit.  If you want a 2.15" tire bead width CB750's will also lace on.
Offline westondc
  • Wes Mantooth
« Reply #5 on: June 07, 2010, 07:28:57 PM »
hey thanks guys. Yeah the idea is to buy a new rim, not buy used and possibly endup with another bent rim. So on to the next question... How difficult is it to respoke these rims and should i use the same used spokes or new ones?
1972 Honda CB500k1
1971 Honda CB350k3
Offline nowhere_fast
« Reply #6 on: June 07, 2010, 07:40:47 PM »
i recently respoked my first set of wheels. its not as hard as it seems..takes a little time and patience, study the pattern of another 40 spoke wheel.. do one side at a time, start with the spokes that come from the inside of the hub, then do the outer spokes, flip the rim, and repeat. its a simple 4 cross pattern. if you can, get another wheel to look at and follow the pattern, it will go a lot easier. I actually used my old spokes, but when i was looking for new ones i was reffered to http://www.buchananspokes.net/  It looks a lot more intimidating than it really is.. theres only one way to learn.. good luck!
« Last Edit: June 07, 2010, 07:42:38 PM by nowhere_fast »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7 on: June 07, 2010, 08:14:46 PM »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #8 on: June 07, 2010, 08:37:55 PM »
Hey Wes,
As nice as your bike is, it will be worth the extra money for new spokes. And use stainless, if you plan to keep it.
Good Luck.
Offline westondc
  • Wes Mantooth
« Reply #9 on: June 08, 2010, 01:39:49 PM »
got mine here
http://www.powersedge.com/pages/parts/viewbybrand/7/default.aspx
thanks for the link, thats exactly what i was looking for. not a bad price either.
i would like to respoke with new spokes but buchananspokes is asking way more than i want to spend at $90+ a set. is it ok to use the original spokes that are already on my bike? how about the $30 set of spokes from parts n more?
1972 Honda CB500k1
1971 Honda CB350k3
Offline tlbranth
« Reply #10 on: June 08, 2010, 01:54:52 PM »
West, I used Parts'n'more spokes for one wheel and Sudco for the other. I'm happy with both. Parts'n'more is cheaper. Don't sweat lacing the wheels. This was my first time and it wasn't that hard. Take your time, know what it is you're trying to do and you'll do fine. Build a wood stand for the wheel and spring for a cheap dial indicator at Harbor Freight. I think this is the instruction set I used - not sure.
http://www.webbikeworld.com/motorcycle-wheels/spoke-wheels/
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
