Author Topic: Which front sprocket? '77 CB750K  (Read 805 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: January 13, 2011, 10:05:19 AM »
Just thought about this.. the sprocket off my old (destroyed) '76 750F motor is a 17-tooth.. standard for the replacement '77 750K motor is 15-tooth. What would be the result of using the 17-tooth sprocket as opposed to the 15-tooth one? Or should I look for a new sprocket?
Offline Kong
Re: Which front sprocket? '77 CB750K
« Reply #1 on: January 13, 2011, 10:50:45 AM »
You will lose acceleration but what you will gain is a top end at lower revs.  Great if you spend a lot of time on highways, not very good if you drive the twisties most of the time.  While it has real no effect at all on power it will feel as if you have lost power to go up on the front sprocket's number of teeth.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
