Author Topic: Master cylinder question  (Read 864 times)
Offline mrrch
« on: June 18, 2010, 02:23:42 PM »
How do tell the difference between a master cylinder for a K (single disc) and an F dual disc)? I am assuming the piston is larger for the F due to 2 brake calipers instead of one on the K bike. I'm looking for a period correct master cylinder for my 77 that is getting dual brakes up front.
my build
Offline simon#42
  • liverpool
Re: Master cylinder question
« Reply #1 on: June 19, 2010, 06:28:36 AM »
the fluid reservoir  is much larger on the dual disc master [ f2 master ] . i improved my dual disc set up no end by fitting the early single disc master , there is a bit more lever travel but alot more brake
Offline mrrch
« Reply #2 on: June 19, 2010, 09:32:06 AM »
I keep getting different answers when researching the topic. If the stock master will work with more lever travel I think I'll try it first (I've got large hands anyway)
my build
Offline Alan F.
« Reply #3 on: June 19, 2010, 07:05:32 PM »
It will work, but do you really want to get the lever against the bar in a panic stop?
Offline mrrch
« Reply #4 on: June 19, 2010, 08:04:10 PM »
That's what I mean. Different answers. I got a master coming from a 78 F model that I will try first seeing as it had dual caliper front brakes.
my build
