Author Topic: 550 bobber attempt  (Read 17440 times)
Offline COMB2
550 bobber attempt
« on: June 20, 2010, 07:53:19 AM »
Well been looking around here for a week since I picked up my 1976 cb550. It was a find on craigslist about 15 min from my house. Got it for $900. Not sure if thats good or bad but after seeing some Jap Bobbers it's what I wanted.
Plans are to hardtail it with most of the other bobber stuff. Figure it out as I go  I guess.
Here she is the way I got her. Started with battery and kicker so I guess thats a good start.
Here she is at the end of day 1
I'll try to keep this updated and hopefully I can get some help from you all if I need it
traveler
Re: 550 bobber attempt
« Reply #1 on: June 20, 2010, 07:59:19 AM »
why did you cut the engine crade pipes???
Now your engine alignment points are WAY off.
Don't forget to put slugs in the pipes to ensure strong welds.
~Joe
Offline COMB2
« Reply #2 on: June 20, 2010, 11:50:42 AM »
Why did I cut the pipes? I don't know! Looked like thats what I needed to do.
I'm going to bolt the motor back in to make sure it all lines up before It gets welded.
I got slugs for the connections.
Again this is my first attempt at choppin up a bike I'm sure it will have plenty of .......character  lol
Offline COMB2
« Reply #3 on: June 20, 2010, 06:30:50 PM »
Thru the motor back in and lined  up everything. It was all crooked without it in.
Friend of mine is turning down some slugs for the tail. I have  bigger tail diameter than the original frame diameter. He's going to take 1/8" to a 1/4" off of half to get it to fit in original frame
Offline 750four
  • Bomb's away!!!
« Reply #4 on: June 20, 2010, 07:44:59 PM »
Take some angle iron and brace up the frame. That way it will be easier to locate your motor mounts. Also you could leave the swing arm in to make sure the rear is square and the trail is good. I left my swing arm in until the rear end was completely welded in. Then just cut it out. Might save you the head ache of squaring things up later on. Good luck. should be fun
Offline COMB2
« Reply #5 on: June 26, 2010, 09:03:23 PM »
Well got half the tail tacked up. You actually got to think this stuff out.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: June 26, 2010, 09:25:08 PM »
I want to go back to June 20th ;)`
Offline shane
« Reply #7 on: June 27, 2010, 09:55:25 PM »
wow, talk about having some balls... Wasn't too bad to begin with, and you just chopped it in half... Effin crazy. Staying tuned for this one...
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #8 on: June 30, 2010, 07:04:04 AM »
i gotta see this...
what are you thinking for bars, tank, etc?
Offline COMB2
« Reply #9 on: June 30, 2010, 08:39:46 AM »
Got 15" apes for bars, solo spring seat and a tear drop tank
Offline hotpocket
« Reply #10 on: July 02, 2010, 10:58:43 PM »
awesome man.  i love my apes.  have you ever had them on a bike before?
Ah, the patter of little feet around the house. There's nothing like having a midget for a butler
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #11 on: July 02, 2010, 11:15:41 PM »
Are you going to lower the front so the bottom of the frame is parallel to the ground? (I vote for "yes" ;D)
–Captain Horatio Hornblower
www.thehairynickel.com
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #12 on: July 02, 2010, 11:21:54 PM »
Dude, you can't just cut a bike in 1/2 and not come back with photo updates :o
Offline Ogri
  • Thinks he's a
« Reply #13 on: July 03, 2010, 02:48:18 AM »
What's your new trail measurement now ? Looks like it'll be more than 6"...it might be a bit hard to steer at low speed.
Offline COMB2
« Reply #14 on: September 14, 2010, 05:31:35 AM »
Well I finaly got it to a spot where I could take it off the lift and roll it around. Fail!!! Yea the trail is way to long the front just flops when you turn it. The tail is also to low which don't help with the trail. I need to chop the tail off and restart. Another part that doesn't help is I found out at some point the front of the frame was lengthened to add 4" and the forks extended to give it a chopper look, that don't help with the trail problem either. Now the solution? I found a member here not to far away that had the same frame properly hartailed and I picked it up and I'm on the right track now. I'll have to post up new pics of it.
I do have a good part bike now
Offline COMB2
« Reply #15 on: October 10, 2010, 08:14:03 AM »
OK GETTING CLOSER
Tail light made from Kettle One drink mixer, All wiring under seat in Kettle ONe bottle chiller temp battery for testing
Tank with sight gauge and speedo
Offline CrankyOldGuy
  • Wish I was a
« Reply #16 on: October 10, 2010, 08:47:31 AM »
Amazing how your project has turned out so far  :)
With respect to your sight gauge, aren't you concerned that "someone" may give it a yank.  I have visions of fuel spurting out over a hot engine.
Harry O.
750 K1 Original Owner
Offline UPHOTO
« Reply #17 on: October 10, 2010, 02:32:23 PM »
hahahaha wow......
just something about it.
I like it!
Offline DaytonGuy
« Reply #18 on: October 12, 2010, 05:06:26 PM »
Any chance you can take some pics of how you set up the electrics under the seat?  How are they mounted inside?  Where does the wire harnes enter?  etc.  pics would be GREAT!
You bike looks pretty sweet.
Offline COMB2
« Reply #19 on: October 12, 2010, 05:58:19 PM »
Well the electronics are kind of just thrown in the container. I did how ever coat the inside with several layers of liquid tape. I drilled holes in the side and used rubber grommets so the wires would not rub. Not sure if it's going to get to warm in it or not but I see lots of guys putting them in oil tanks.  Most of the wiring on this bike is gone. I keep all the main stuff like the regulator, solenoid , fuse box ect. Snipped all the wires I didn't need and ran new with connectors in case I needed to take it all apart. I then shrink tubed all the exposed stuff. The 3 switches are kill, headlight and starter. They are just toggle switches
Offline COMB2
« Reply #20 on: October 12, 2010, 06:03:12 PM »
Harry O.
Never thought of it and I'm still not going too !!! LOL I guess and ass kicking will be in order if some one does that
Offline sky56
  • would you like to see my
  • Chgo winters can suck but great time to wrench
« Reply #21 on: October 12, 2010, 06:09:39 PM »
awesome build looking good. Ive really become a fan of those in sight tanks but in chicago i too would be worried about the yank of the line
Many honda bikes and a lifted 75 Chevy K5
Offline COMB2
« Reply #22 on: October 22, 2010, 08:03:06 PM »
I am going to have to put something on it I was putting it up on the trailer today and bumpped it good and got some gas on me. I can barely pull the hose off but bump it and it leaks a bit >:(
Offline COMB2
« Reply #23 on: October 22, 2010, 08:04:16 PM »
A bit more done
chain tensioner to take up slack do to rear whell being fixed b/c of drum brake bracket
got the pipes wrapped
bungs to mount the fender (front fender moved to rear)
Bike as of now
Also did new brake shoes front and back, new clutch cable, front brake cable  and throttle cables
Carbs are being cleaned and rebuilt. New front tire on the way, New dyna coils and dyna electronic timing coming also
« Reply #24 on: October 22, 2010, 08:18:55 PM »
Good luck trying to tune that bike with those pipes and also get used to shorter valve life, no back pressure is not a good thing..
