Author Topic: Lean running K5  (Read 1109 times)
Offline tommye
Lean running K5
« on: June 21, 2010, 10:18:39 AM »
Hi!
Been tinkering for a while with a nice condition K5 CB750 with the great help of Hondamans' book  :)
When I got it, it was running sort of ok, but not like I expected. Tendency to foul plugs during cold starts, no real rush at higher rpm:s, abrupt clutch engagement, weird roadholding and so on.
Stuff done so far:
- Carb rebuild with Keyster kits, main jets changed from 105 to 110. Needle clip position 4 from top - no change
- Fixing the choke linkage in order to apply same amount of choke to all 4 carbs
- New HM341:s from David Silver were installed in 2007
- Airbox vents opened up to 50% more area. Holes drilled + forming with heat gun.
- Centrifugal advance shaft trued to 0.05mm => timing became rock soilid!
- Centrifugal advancer tabs bent + weights filed => full advance timing at second marker (more advance)
- Idle mix screws at 1 turn
- Plugs changed from DR8ES to D8EA => no more plug fouling when cold
- Wheels carefully aligned including centering of front rim, new rear shocks, oil in both fork legs (!) => much better roadholding
- Steering head roller bearings
- Yamiya improved clutch kit + oil hole drilling of outer drum => better clutch operation, less slip but still some gearbox clonk.
Now the bike is a pleasure to drive, easy to start and even shows some signs of power at higher rpm. Plenty of torque at low/mids.
There are 2 problems still: when warm (only then) ther is a slight stumble when gently  accelerating off idle.
The plugs are WHITE, both after a full throttle run/immediate stop and also after normal driving.
Is there anything else I should think of before going into jetting ???
Any advise appreciated !!!
Tommy
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Lean running K5
« Reply #1 on: June 21, 2010, 04:15:20 PM »
Richen your needle clip setting (forget if that is up or down).
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Lean running K5
« Reply #2 on: June 21, 2010, 04:26:53 PM »
Standard clip position is 3rd down from memory.
Offline BLUE71TURBO
Re: Lean running K5
« Reply #3 on: June 21, 2010, 04:32:48 PM »
 To richen you must raise the needle. You also can install a different tapered needle to fine tune.  ;D
Re: Lean running K5
« Reply #4 on: June 21, 2010, 04:35:35 PM »
Oh yeah, and don't use the Keyster needle, I heard that is the one thing from the kit you do not want to use.
