Author Topic: What the hell is supposed to be here?  (Read 1295 times)
Offline 750K8 Kev
« on: June 21, 2010, 05:49:06 PM »
Should there be some sort of hose here? is this ok to be plugged up?
Offline Damfino
Re: What the hell is supposed to be here?
« Reply #1 on: June 21, 2010, 05:53:03 PM »
Tach drive cable?
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline jbonham
  • Um, do you know where this goes.......?
« Reply #2 on: June 21, 2010, 05:57:29 PM »
Definitely the tach cable. I would say that if your bike doesn't currently have a tach, that it might be a good idea to cover the hole with something so that dirt and other miscellaneous particles don't get in there and gum it up.
Did the bike originally come with the rubber stopper in that hole? If so and you don't notice that it is causing any damage for now, I would leave it. If you have plans to put a tach gauge on the bike then obviously at that point the end of the tach cable would go there and a screw is then inserted through the side to hold the cable in place.
I am kind of new on this forum so if that doesn't sound right to anyone else who is more experienced please throw your two cents in!
Good Luck.
Judd
« Last Edit: June 21, 2010, 06:04:27 PM by jbonham »
1971 CB750 K1
2003 Kawasaki Vulcan Classic 1600
Offline 750K8 Kev
« Reply #3 on: June 21, 2010, 05:59:26 PM »
Thanks! I didn't get my tach yet, so that explains it
« Reply #4 on: June 21, 2010, 08:20:13 PM »
Do you have an owners manual yet  ??? Better get one before you get to those sparkler plugs  ;D
Offline eurban
« Reply #5 on: June 22, 2010, 05:19:14 AM »
Yes, go to the download manuals post (first post in the SOHC/4 Bikes section of the forum) and download the factory K8/F3 manual.  It will help!
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #6 on: June 22, 2010, 05:59:51 AM »
 ??? Don't forget a new tach seal! I am cleaning a mess from a bad one today.
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
