Author Topic: My first project cb350f guidance needed :) Ive got a ROLLER Pic update 2-21-12  (Read 4450 times)
Offline andy8190
Re: My first project cb350f guidance needed please :)
« Reply #25 on: November 21, 2011, 04:14:34 PM »
Aight so the project has started up again since I have moved and gotten settled in. First up is the engine which i have cleaned and painted
I then got the frame painted 2 days ago. I used valspar tractor paint that i got from tractor supply company. I brushed it on so it doesnt look professional but will be easy to repair chips. The brush marks leveled themselves out nicely, it looks wavely only because i put it on THICK. I will report back later on what i think of long term durability but for now im happy. Has a nice gloss to it. I dropped off my pistons today to get honed and tomorrow I am going to lap my valves.
When installing new gaskets do i need to wipe them with a thin layer of oil or should they be installed dry?
Offline andy8190
« Reply #26 on: February 16, 2012, 06:41:41 PM »
okay a little update on some work i have done. I haven't gotten many comments back so far but I am still trekking on. Please guys I like the feedback so give it a go
Carb cleaning done, i used a vinegar, lemon juice, and water mix to help get them clean. Worked really well
Cleaned off my pistons and reinstalled them with new rings on them
Cleaned the head up, lapped the valves and reinstalled those with new oil seats or seals whatever they are called
The engine back together pretty much
and back on the frame to this point
« Last Edit: February 16, 2012, 06:46:55 PM by andy8190 »
Offline lucky
« Reply #27 on: February 16, 2012, 07:05:26 PM »
Cool, Andy!  Digging the seat!
I've heard that Diet Coke can help un-stick rings when taking a motor apart.  Never tried it myself, though.
Chris
That is total baloney!!
All a diet coke will do is get the cylinder wet and cause it to rust.
Do not do that.
There is a bunch of people on the internet that says cokes have acid in them and will eat up a nail. FALSE!!! If you do not believe me then actually put a nail in a coke and leave it as long as you want. It will just come out wet. Even after 3 months.
Offline lucky
I hope your re-cut those valve seats and tested to see if the valve wiggles in the valve guide. If it wiggles more that about .004 it is no good. Check your workshop manual for test procedure and wear limits.
You cannot just lapp a worn out valve.
You asked for guidance. Here it is.
Offline andy8190
not sure what you mean by recut them but i will check the manual. I didnt do anything but lap them, now I am worried i did a lot of work for nothing :(
Offline andy8190
they looked in pretty good shape before i lapped them though, i just lapped them because i figured why not while it was apart.
Offline andy8190
just wanted to drop in and give my praise to evapo-rust, that stuff is amazing
Offline hoodellyhoo
  • CB350F
« Reply #32 on: February 21, 2012, 03:29:41 AM »
Chris
Do not do that.
it will remove the rust from a rusty nail, hence the thought that it will remove the rust from a rusty piston ring.
Offline andy8190
Boys i am happy I officially have a ROLLER now :)
So am i correct if i take off the head and do a leak test and nothing leaks then I do not have to recut the valves?
here are some pic updates
also does anyone know where to get some dust seals for the forks? both the kind that goes in the fork and the ones that go on top of the fork?
