Hi Sol,
I have a Clymer Honda CB650 Fours 1972-1982 manual, let me just say that it is invaluable. You can get one on ebay for like $10
http://cgi.ebay.ca/CLYMER-HONDA-CB650-FOURS-1979-1982-REPAIR-MANUAL_W0QQitemZ8037752639QQcategoryZ34237QQssPageNameZWDVWQQrdZ1QQcmdZViewItemI've never hard to replace the bulbs on the bike, but here are what the replacement bulbs section of the manual says:
Tail/brakelight: 12V 8/27W - SAE no. 1157
Directionals:
Front: 12V 23W - SAE No. 1034
Rear: 12V 23W - SAE No. 1073
I think there is a difference between between the 1980/1981 CB650C in some of the electrical details. I've never had to deal with the turn signal relay, but it is described as being under the seat and has a rubber mount. I took a quick look on oldbikebarn.com, partsnmore.com and ebay, but couldn't turn up a part. Perhaps someone on the forum can recommend where to get a relay, or suitable part?
I have had problems with the turn signal switch located on the handlbars: I broke the little lever that held it together. You may want to take that apart and make sure that the mechanical switch is operating properly. Another simple thing that may help is going over the wiring, looking for shorts, and sparying all electrical contacts with contact cleaner. When I did that, a few nagging intermitant electrical problems I was having disappeared.
Signs of cam chain problems? Not sure what the problem would be.. maybe an engine with symptoms of poor timing. I listen for a noise that sounds like something slithering in the engine. The instructions for tightening it are in the clymer manual, they are
1. Bike centerstand
2. Turn the ignition switch to off and put in neutral
3. Remove all 4 spark plugs
4. Remove ignition cover (the round part on the side of the engine that says Honda)
5. Loosen the camshaft chain tensioner locknut. This is a nut located just above the starter motorcover, in between the 4 cylinders.
6. Using a wrench (15/16 size I think), slowly rotate the crankshaft clockwise while slowly tightening the camshaft chain tensioner locknut. Rotate the crankshaft at least 4-5 times while tightening the locknut.
7. Reinstall the ignition cover and spark plugs
Also, there are a few tips on how to get a better adjusted cam chain on this forum as well, be worthwhile doing a search and seeing what comes up as it has been discussed here a lot in the past.
The manual says every 4000 miles for oil changes and valve adjustment, but I think I do it a bit more than that, usually depending on the sounds coming from the engine and the appearance of the oil.
Once again though, the Clymer manual is a worthwhile investment.
Let us know how it goes, eh
Rob
