Author Topic: Mirror Blurrrrrr  (Read 3334 times)
Re: Mirror Blurrrrrr
« Reply #25 on: June 23, 2024, 05:19:18 PM »
I bought aftermarket mirrors and it put me in category 1.  Clear picture no matter the speed.
« Reply #26 on: June 23, 2024, 08:08:06 PM »
Yeah, but you have a K0, right?
They were the ones promoted with the wineglass on the tank, IIRC(?).
:D
Offline Rosinante
  • All Generalizations are False
« Reply #27 on: June 23, 2024, 11:03:17 PM »
When the Gullwings came out, I recall the cigarette standing on the fuel tank trick.
1978 CB750K
Offline willbird
« Reply #28 on: June 24, 2024, 04:19:26 AM »
CB750K2, I have modern Honda part number mirrors. #4 for sure. Back in the day folks would tape coins to the back side of the mirrors to find the magic amount of added weight to dampen vibrations, then I presume add that amount of weight somehow.
Bill
« Reply #29 on: June 24, 2024, 08:53:19 AM »
:D
I remember that from your book - I think.
The K0 came with crappy aftermarket and I replaced it with bar end mirrors.
Offline Rosinante
« Reply #30 on: June 24, 2024, 04:50:39 PM »
These reports of factory mirrors performing poorly is surprising and disappointing to me, but then I notice that HondaMan tells us why they do this and what the inexpensive solution looks like.
I've run into people before who generously share their deep and thorough and intimate understanding of a particular machine.  At times I have declined to act on their advice and usually regretted it.  Today, when these people talk, I listen carefully.
1978 CB750K
Offline carnivorous chicken
« Reply #31 on: July 08, 2024, 11:39:49 AM »
...you can tell what model the cars are?
I could in 1972, today not so much.
I'm not talking about those in the mirrors...just all of 'em...
I still have the factory mirrors on mine, they are pretty good when I re-glue the mirrors to the frames: about every 10 years or so the rubber insert that holds the mirrors shrinks (some more) and then they start shaking and vibrating, so I have to glue them down.
Again.
My 550 mirrors are a little shaky -- how does one go about doing this? Use a pick tom pull out the rubber around the mirror?
« Reply #32 on: July 08, 2024, 03:13:54 PM »
Again.
If they are loose you can use rubber cement, Walther's GOO (if you're a model-building hobbyist), or Pliobond: squeeze it in those opens spaces around the rubber edges. It keeps the water out, too.
That's what I do - and they are about due again: it's been at least 10 years since I last did them.
Online denward17
« Reply #33 on: July 08, 2024, 03:33:18 PM »
Again.
Mark, do you put the goo in around the edge (between the glass and mirror frame)?
« Reply #34 on: July 08, 2024, 05:04:14 PM »
Again.
Well, yes and no: the first time I did it the rubber had pulled away pretty evenly around the frame. That was in 1981 or so. The last time I did it was in 2006, and the rubber on one of them had a crack in it that let some rubber spring out toward the frame and some stayed by the glass. So that time I just filled in the gaps. Now one of them has some new gaps along the lower side and the other is opening near the top: I'll just squeegee some of this GOO into those cracks to close them fully up again.
The nice thing about the Walthers GOO is it's grip, and lack thereof: it is a mixture of Pliobond and rubber cement (judging from the smell of it) that is 100% waterproof when dried, plus being 99% sun-proof after 2-3 days. It is the parking outside at work that always breaks it down, in the direct (and very fierce) Colorado hi-altitude sun that eventually hardens it enough to crack. It stays fully flexible forever, so it is a perfect glass-holding glue.
« Reply #35 on: July 08, 2024, 06:47:59 PM »
I’m surprised PeWe hasn’t piped in. He has a great set of mirrors on his K5 and a few years ago I bought a set for a K4 I was riding at the time. I think they came from Z1? PeWe?
