Author Topic: cb500 front rim options  (Read 5892 times)
Offline Quorthon
  • Pace till death
« on: June 25, 2010, 11:58:14 PM »
I have a hop in my stock front rim.  What are my options for replacements?
Are there any oem 19" aluminum rims I can look for to relace to my stock hub?
My buddy said maybe something from a Goldwing?
Thanks.
1972 cb500/4
Offline camelman
  • Man... Myth... Legend
Re: cb500 front rim options
« Reply #1 on: June 26, 2010, 01:35:07 AM »
There are plenty of them out there.  However, if the rim is still in good condition overall, then I'd suggest taking it to a machine shop to see if they can straighten it.  Many machine shops have the knowledge to pull it off (it isn't really very hard), and it will cost much less than a new rim.
I remember reading a 4WD article on which rims were the toughest.  The testers took the tires off each rim to be tested, and drove a fullsize truck offroad on some gnarly surfaces to see which rim held up the best.  Afterwards, they had the rims straightened at a local machine shop in southern California.  Total cost for straightening was less than $40 each.  That was just a few years ago, so I bet your rim shouldn't be more than $50 or so to straighten at a legit shop.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #2 on: June 26, 2010, 02:47:25 AM »
i put a pair of made in california"sun rims "on my 500,i like them .
Offline Quorthon
  • Pace till death
« Reply #3 on: June 26, 2010, 01:05:09 PM »
Are those aluminum?  I would really like to find and aluminum rim.
1972 cb500/4
Offline neil young
  • striving to be an
« Reply #4 on: June 26, 2010, 02:38:16 PM »
pretty sure that the reverse Comstars fit....and you can set up a dual disk front brake with them.
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline camelman
« Reply #5 on: June 26, 2010, 05:33:04 PM »
Check on eBay for dirt bike rims.  They come in 19" diameter pretty often, and are relatively cheap.  You can get a nice Excel rim for under $100 pretty easily.  I have seen debate over whether a road bike tire will fit a dirt bike wheel, and the consensus is that it will.
Another good option is to go to Buchannan spoke and wheel.  They have brand new alloy rims, although you will pay at least $180 per rim.  They have spokes kits too if needed.
I've also seen XS650 wheels that claim to have 19" stock alloy rims.  I can verify that the rears were alloy (for certain years), but am unsure of the fronts.  If the front is alloy, then that is another option to take since XS650 wheels are usually very cheap on eBay, and are quality name brand.
Camelman
Offline Quorthon
  • Pace till death
« Reply #6 on: June 26, 2010, 08:15:09 PM »
Thank guys, I'm checking into all that.
I really wanna stick with the spokes and stock hub though, no mag wheels.
Anything else?  Also maybe just a cheap steel alternative if not aluminum?
1972 cb500/4
Offline crazypj
  • I'm brill, me
« Reply #7 on: June 26, 2010, 08:38:27 PM »
Most MX bikes for last 5~6 yrs have 19" alloy rear wheel.
They wont work for you though as you have 40 spoke hubs and they are either 36 or 32 hole.
 You may find a Goldwing rim on eBay though.
 550 hub is through drilled fitting dual disc is relatively easy and has been covered multiple times
 If your re-spoking, I would go to WM3 rim.
Offline kajtek
« Reply #8 on: June 27, 2010, 03:33:48 AM »
its uk based but these people have a lot of rims at good prices:
http://www.central-wheel.co.uk/
ashley
1978 honda cb400f supersport
Offline Quorthon
  • Pace till death
« Reply #9 on: June 27, 2010, 03:30:47 PM »
I'm seeing a bunch of gl1000 front wheels on ebay.
Can I use the hub off these on my 72 cb500?  Or would I have to lace it to mine?
1972 cb500/4
Offline Quorthon
  • Pace till death
« Reply #10 on: June 28, 2010, 07:13:43 PM »
Anyone?
1972 cb500/4
Offline Quorthon
  • Pace till death
1972 cb500/4
Offline crazypj
  • I'm brill, me
« Reply #12 on: June 29, 2010, 10:47:32 PM »
If it bolts straight in you got lucky.
If it doesn't, well you have a nice rim and probably a set of spokes
other than the labor, you still win
PJ
Offline Quorthon
  • Pace till death
« Reply #13 on: June 29, 2010, 10:57:42 PM »
Yeah, Ill just order it and see what happens.
If it does bolt right on then it would be a pretty cool cheap upgrade for 500/550's.
Thanks.
1972 cb500/4
Offline Zaipai
    • My Home page
« Reply #14 on: June 30, 2010, 05:47:01 AM »
Well that rim/hub has 40 spokes so that's good. So its only a matter of the dia of the axle that would keep you from using it.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline crazypj
  • I'm brill, me
« Reply #15 on: June 30, 2010, 06:01:31 AM »
Uuuhh............................................... No
axle diameter is always least of problems, it's easy to swap out bearings.
 The width of hub is limiting factor, if it wont fit between fork legs its no go, machining usually isn't cost effective
PJ
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #16 on: June 30, 2010, 06:25:39 AM »
Gotta buy this today.
Would this rim and hub work?
http://cgi.ebay.com/ebaymotors/77-HONDA-GL1000-GL-1000-GOLDWING-WHEEL-FRONT-RIM-8-_W0QQcmdZViewItemQQhashZitem563b342e06QQitemZ370360462854QQptZMotorcyclesQ5fPartsQ5fAccessories
Yes.
While I have never put a GL wheel on a 550, I have used a 750 wheel on a 550 and the GL wheel on the 750.
   From what I have learned about the 6 bolt front wheel, they all used the same hub (except for the early 750 Sandcast) and interchange easily with each other. Use your stock 500/550 brakes, axle, forks, bike, nuts and bolts, etc.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Quorthon
  • Pace till death
« Reply #17 on: July 01, 2010, 10:59:38 AM »
Awesome.   Thanks alot!
1972 cb500/4
Offline lone*X
« Reply #18 on: August 12, 2010, 12:26:13 PM »
Hate to resurrect a month old thread, but was wondering how the GL1000 hub worked out on the 500/550?  Isn't the speedometer drive different?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #19 on: August 12, 2010, 01:07:09 PM »
Was there a trauma that caused your wheel hop? Did you own the bike when it did not have the hop? and then was there a trauma to the rim that caused it? If yes then proceed.
If not, well an aluminum rim is cool, but it may not cure the hop. Wheel hop can come from a tire, a sticky fork (springs, old oil, sticktion.) Maybe something in the rear even. All the suspension parts need to be in good order.
Just a thought.
Offline Quorthon
  • Pace till death
« Reply #20 on: August 12, 2010, 07:25:01 PM »
I'm actually just getting around to doing some minor truing and media blast/paint to the wheel I bought.  I haven't checked the speedo drive, guess I should...
The front rim has a visible flat spot in it.  Although I guess I'm still not 100% that is the cause, it is at least part of it.
1972 cb500/4
Offline fishhead
« Reply #21 on: August 13, 2010, 06:00:18 AM »
 Yes,
 The GL speedo drive is different than the CB. Use the CB speedo drive with the CB forks (or GL speedo drive with the GL forks)
