Author Topic: 500 to 550 rear wheel?  (Read 596 times)
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« on: June 26, 2010, 04:45:55 PM »
okay, im swapping over the 16" wheel laced on a 500 hub. im having an issue of a gap on the left side between the swing arm/adjuster to the hub itself. can i just use a washer to shim that? what do you think. im using the spacer that came with the 500 wheel which is little shorter.
the hubs should be the same, i think. so im kinda scratching my head here
any input?
btw, the gap is about 1/8-1/4"
