ok, i just went and did some checking, and i hope it helps cause its only about 10*F here (coooold).
i have two different size pivots. one is the more common one that i have on my 76K. i measured it on the splines at about .75in. the other one i have is from a 78F (rear disc). it measures at about .65in. on the splines.
i dont know which one you would have on the 78K. if you could measure and compare it would maybe tell you. if my measurements arent exact, its cause the 76K was hard to get to. if you come up with something different, i can take a better measurement. let me know.
if you need the smaller 78F one, i could get rid of mine.
the part # for the pivot shaft for K3-K5 is 46570 300 010. that should be the same as the bigger one (76) if that is the one you need.
i dont have any numbers for other years.
