Author Topic: 1978 CB750 parts id help.... please.  (Read 1212 times)
Offline Hootis29
    • Hootis Motor Sports
« on: June 27, 2010, 08:32:06 PM »
Hey guys,
I am putting together a 78 cb750, it came to me in boxes.
I have not worked on much this new. :)
Can you help me identify these parts.
I know where the key goes.  ;)
Not sure on the hoses or the little silver bracket, I did figure out the curved black piece.... I think.
Thanks!!!!!
« Last Edit: June 27, 2010, 08:34:58 PM by Hootis29 »
Paul " Hootis" Noskowiak
1975 CB 750
1975 CB 550 (Cafe Project)
1973 CL 350
1972 450
2006 Buell Ulyesses
2001 Buell Blast (Custom)
1977 Triumph Bonne
1975 XL1000
1972  750 Commando
Assorted other CB's mostly 500, 550's
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 1978 CB750 parts id help.... please.
« Reply #1 on: June 28, 2010, 03:52:30 AM »
The yellow hose is the fuel overflow from the bottom of the fuel tank that redirects any fuel spillage within the fuel cap compartment down to the ground. Mine, also a CB750K8, is routed from under the tank, over the frame rail next to thr rear tank rubber mount, then down directly in front of the battery (following the battery vent tube). The splice in the tube ends up at the top front of the battery to permit tank removal without pulling the entire hose out.
The smaller bracket mounts inside the alternator stator cover to hold the field and stator wires out of harms way, away from the moving parts.
The black hose looks to be a vent or overflow tube, I'd have to look around to find out which one.
As for the larger, shiny bracket, it looks very familiar but I can't pin it down. I'm thinking it mounts down around the centerstand, behind the rear of the engine to capture one or more overflow/vent tubes to hold it (them) out of harms way. It's awfully clean though, I'm wondering if it might be from inside the engine case.
I'll repost if I find out for sure.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« Reply #2 on: June 28, 2010, 06:20:36 AM »
i think MAD is right about the big bracket going down near the stand. I believe it goes on the right side of the bike near the swingarm pivot.
« Reply #3 on: June 28, 2010, 09:22:53 AM »
Yep, that's what I thought too. See attached pdf. I belive the part #1 is the bracket in question, and I believe it is either for the fuel tank spill/overflow or for the crankcase breather from under the battery tray. I'll have to look at mine to know for sure.
TAMTF...
Wilbur
Projects:
Offline jbonham
  • Um, do you know where this goes.......?
« Reply #4 on: June 28, 2010, 09:28:38 AM »
Of course the key, well, is the key. Ya know to start the thing? LOL! No offense.
The black cable in the top right of the pic looks like what is connected to the bottom of the speedometer but I may be mistaken.
The other brackets and such i am not sure about though.
1971 CB750 K1
2003 Kawasaki Vulcan Classic 1600
