Did a search with no hits, hope this isn't too redundant.
Clymer says "Torque down the head mounting nuts and bolts in the sequence shown in figure 42 to 13.7 -15.2 ft lb".
Won't this potentially strip the six 6 mm bolts?
The site shop manual pdf specifies the 8mm nuts at 14.5 to 18.1 but says nothin about the 6mm bolts. Generically, the highest grade 6mm torque spec is max 10 ft lb, but for sure this does not apply to aluminum threads.
