Author Topic: Gas leaking!  (Read 766 times)
mossen
Gas leaking!
« on: July 03, 2010, 09:00:47 am »
My '78 550 leaks gas from the drain plugs! It is in need of those little carburetor drain plug gaskets, as all 4 are basically destroyed from 30+ years of use. The rest of the carbs are OK... I don't need the whole rebuild kit, just those 4 little gaskets. Has anyone been successful at locating something that works for this?
Thanks!
mossen
Offline Johnie
Re: Gas leaking!
« Reply #1 on: July 03, 2010, 12:02:04 pm »
I have found a great supply of rubber washers at the local Ace hardware store. Not sure if your are the rubber or crush aluminum washers. They usually have a bunch of drawers in the plumbing section with a ton of different sizes. You just have to be willing to look through all the drawers and I bet you find something that will work.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
