Author Topic: Fork Seal Removal...any bright ideas?  (Read 1642 times)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« on: July 05, 2010, 11:35:12 AM »
So...i've replaced fork seals before and they are ALWAYS a chore to get out.  But I've never had one put up this much of a fight.  I've hit this thing from every angle and it is sufficiently chewed up as a result.  But it won't budge...and now I have no more "lips" to push against to get it out.
What now?
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline Popwood
Re: Fork Seal Removal...any bright ideas?
« Reply #1 on: July 05, 2010, 11:39:43 AM »
Did you try boiling it? It worked for me and my son and others on the site have recommended.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline gmonkey
« Reply #2 on: July 05, 2010, 03:50:50 PM »
I heat mine up with a heat gun.  Hair dryer might work too.  Same basic idea as the boiling but less involved.
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
« Reply #3 on: July 05, 2010, 03:53:42 PM »
Local MC shop owner showed me that a long tire iron/lever, pops them out pretty easily.
Offline elquenada
« Reply #4 on: July 05, 2010, 04:07:22 PM »
I just did this this weekend.  I boiled some water and then gave the seals a soak for about 5mins.  Then I took a BFS and pryed it out, using a shop towel to make sure i didnt mar the metal around the forks.  they popped right out.
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
« Reply #5 on: July 05, 2010, 04:15:20 PM »
I've used screwdrivers before. Difficult to not scratch the seating surface.  The tire iron has rounded edges that don't dig into the soft aluminum.
Offline Toxic
« Reply #6 on: July 05, 2010, 04:29:28 PM »
... and if you scratch the surface like I did you better polish is smooth
Offline GammaFlat
« Reply #7 on: July 05, 2010, 04:43:45 PM »
Use a seal puller (about $7).  I rested a tire flat across the top of the leg and leveraged the puller (fulcrum point) on the flat.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline brycegp
« Reply #8 on: July 05, 2010, 07:33:31 PM »
boiling it worked like charm.
Thanks Elquenada!
Offline elquenada
« Reply #9 on: July 06, 2010, 05:02:16 PM »
glad it worked. though I wont dare take credit for that tip.  i learned everything about my bike here in this forum and i feel forever indebted to pass on the info.  enjoy your new seals.
1975 CB 550
Lope de Vega
Offline brycegp
« Reply #10 on: July 06, 2010, 07:01:01 PM »
