Author Topic: 130/90/16 mounted diameter?  (Read 5503 times)
77cb750
« on: February 12, 2006, 08:27:25 PM »
Hi, can anyone with a 130/90/16 tire mounted on a rim take a measurement of the diameter? I'd appriciate it. Thanks
Offline Dennis
Re: 130/90/16 mounted diameter?
« Reply #1 on: February 12, 2006, 10:07:22 PM »
If I were you I would look for the tire manufacturer's web page for the tire which interests you. Most of  the tire manufacturers put a lot of technical information on their sites. I just browsed through a few selections on the Bridgestone-Firestone site and found that the published diameters of the tires that I looked at ranged from 25.0" to 25.4" in that size. Pick the tire you need (or want) and check it out for yourself.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: February 12, 2006, 10:14:51 PM »
i'll try to remember next time i'm down at the shop.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline cb650
« Reply #3 on: February 13, 2006, 04:12:05 AM »
24 1/4.   tire is half life.
          Terry
77cb750
« Reply #4 on: February 13, 2006, 09:05:47 AM »
Thanks guys, The tire I have is a Cheng Shin Barracuda 130/90/16. I can't find anything from them that gives sizes. I looked. Oh well i'll just mount it and see how it looks compared to the 100/90/19 front (same model tire). Thanks
Offline Dennis
« Reply #5 on: February 13, 2006, 12:01:09 PM »
You can alway approximate it by arithmetic.
Sidewall = nom width X Aspect ratio
Sidewall X 2 + ID = OD
130*.9 = 117 /25.4 =4.606"
4.606 *2 = 9.212 + 16 = 25.2"
77cb750
« Reply #6 on: February 13, 2006, 03:23:58 PM »
Thanks Dennis, but are you sure your equation is correct?
130 x .9 =117
117 x 2 = 234 + 16 = 250
what value is used to get from mm to inches? I'm missing something.
Offline 8 Track
  • 1976 cb750
« Reply #7 on: February 13, 2006, 04:39:35 PM »
Divide mm by 25.4 to get inches, or multiply mm times .03937 to get inches.
25.212598425196850393700787401575"
(sorry, having a bad day over here and I was just trying to be funny  :( )
« Last Edit: February 13, 2006, 04:44:48 PM by twostrokecrazy »
My dog loves me for the person I try to be.  Either that or he's hungry.
77cb750
« Reply #8 on: February 13, 2006, 07:18:11 PM »
Thanks TWO.
Offline Dennis
« Reply #9 on: February 13, 2006, 09:57:08 PM »
Like TWO said, divide by 25.4 to change from mm to inches.
Check it over carefully, it works. Divide your 234 by 25.4
