Author Topic: Soooo, new carb boots?  (Read 1002 times)
Offline ev0lve
« on: July 06, 2010, 09:10:33 PM »
Have had an issue with the idle rising as the bike gets warm since I got it back together but this season it's getting a little ridiculous - between 2 and 3 thousand RPM. If I grab the choke full on it will idle just under 1000.
A little pooty (sorry for the technical speak  ;D ) giving it throttle in that condition but it doesn't die outright like I'd expect. Take the choke off and it comes right back to 2 - 3000.
That's gotta be an air leak on the engine side of the carbs, right?
75 CB750K in reasonable tune - it's due though.
Offline Brian G
Re: Soooo, new carb boots?
« Reply #1 on: July 07, 2010, 05:07:57 PM »
Inasmuch as there's been no other response to your post, I'd guess that you've answered your own question  ;D
Nonetheless; I had a similar situation on another make of bike which turned out to be a sticking spark advance mechanism. If, when she's 'idling' at 2-3000 rpm, try engaging first gear and gently let out the clutch against the brake. The revs (obviously  ::)) will drop but if they return to the high speed idle when you pull the clutch back in it would tend to indicate a carburation problem. If the engine speed stays at the lower speed, it may indicate a sticking spark advance. Something to look at, anyways...
Hth,
Brian
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Offline ev0lve
« Reply #2 on: July 08, 2010, 02:55:27 PM »
Hth,
Brian
Sprayed WD40 on the carb boots carb and engine side. No change so maybe the boots are good.
Clutch engaged but returns to 2-3000rpm.
Spose I'll lube the advance when I do the tune up and see unless someone knows something else.
Offline ev0lve
« Reply #3 on: July 10, 2010, 08:51:09 AM »
Hmmm, just screwed the idle out while I was out for a ride. Idles at 1000 no problem.
All I can think is I did the tune in March and set idle in 40 degree weather with what I thought was a fully warmed up engine but in 90 degree weather it's different? Sound like a reasonable explanation?
Still a noob with my 35 year old machine  ::) ;D
Offline BigBoi
  • It's a jungle out there.
« Reply #4 on: July 10, 2010, 11:50:36 AM »
Could be. I play with the idle on my bike everytime I ride it. I increase it while it's cool...ride it for a while, come to a stop and she'll idle around 2-2.5K. I reach down, bring her back down. I'll have to do that a couple of times when I ride to ensure it's at around 1K when hot.
Offline ev0lve
« Reply #5 on: July 10, 2010, 05:09:18 PM »
Is your bike a 750K? My idle knob is behind the petcock between the 1st and second carbs. Not an easy reach - in fact I can only get at it using the tips of both index fingers to turn it.
Now that I think about it I wonder if that's not the reason the petcock was on the right K0 - K4?
« Last Edit: July 10, 2010, 05:13:18 PM by Iggy »
Offline BigBoi
« Reply #6 on: July 10, 2010, 11:15:09 PM »
Mine is a K2. It's behind my petcock as well. I can reach it with my index by wrapping my hand around my number 4 carb.
