Author Topic: Keihin CR26 HELP!  (Read 1336 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
Keihin CR26 HELP!
« on: December 21, 2010, 05:38:00 PM »
OK
So I decided to pull the trigger and order a set of Keihin CR26 Special carbs and when I received them I found a few surprises.
Firstly, I should mention that I asked that the set of carbs be re-racked with a 77 x 100 x 77 spacing similar to that found on the Kawasaki KZ900’s. This spacing is a perfect match to the intake ports on the CB550 head and would require custom intake manifolds similar to the ones Bwaller used to mount KZ Mikuni carbs.
To this request I was told that it would be no problem, just a small additional charge of $41.00 to re-space them to that specification.
When I received the carbs I found the following.
Since discovering this, I have been told by the vendor that the supplier claims all would be fine and that there isn’t a longer throttle shaft available so not to worry.
What says you experts out there?
Re: Keihin CR26 HELP!
« Reply #1 on: December 22, 2010, 12:55:14 AM »
Jimmy, might have been better in the race forum, and who did you get them off?
Sam. :D
« Reply #2 on: December 22, 2010, 07:00:49 AM »
I'm a bit surprised they would sent them this way. Probably not a big issue that the shaft is too short. Is there just one spot where the shaft hole/seal lip is an issue?
You could give them a whirl as is or, pull the shaft fill the hole and machine round again, or buy SS shaft and make your own.
Nice carbs man, would you take a pic straight through the throat please?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: December 22, 2010, 07:58:19 AM »
Brent
Just one location where the seal is breached, but wouldn't that cause tuning and syncro issues?
I'm looking into getting a stainless steel shaft and replacing the whole thing.
Pictures to follow as soon as I get my Bwaller intakes sorted out.
Cheers
« Reply #4 on: December 22, 2010, 08:29:11 AM »
I would like to see a close up shot of the underside of a slide at some point, can't remember what they're like.
Although I made some, the credit for the intake manifolds should go to TG.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: December 22, 2010, 04:16:55 PM »
Sam. :D
Sam
I purchased the Carbs & K&N Pod filters through a place called Power-Barn as recommended by Godfrey from this site.
Mike at Power-Barn is a great guy. Very helpful with a "Can Do" attitude. Others I spoke with just said that there are no CR26 carbs available for the 550 and I would have to use the 29’s if I wanted to go that route. Mike however, said “No Problem” getting CR26 carbs and at what ever spacing I wanted.
When I emailed him these photos, he was as shocked as I was and offered to refund the whole enchilada if I didn’t want to keep them. He also said that the conversation with the sales manager at Sudco (supplier) suggested that this was the longest throttle shaft available and completely acceptable.
When I spoke to Sudco today, Chad (sales manager) was quite rude and reinforced that all CR Special carbs using the wide spacing (ie: Kawasaki KZ, Suzuki GS & others) would receive this setup. That surprised me as I would have expected a longer and better fitting throttle shaft than this as an acceptable factory unit.
