Author Topic: My Temporary Solution to Air Box -> Carb Boots "CB550 Guys"  (Read 7347 times)
DocVile
To start my story - I work for an appliance parts company - ive always been a guy that  says " if i cant find it i'll make it"
With that being said, i own a 77 CB550k - Boots from the air box to the carbs aren't just flowing like water . So i was Checking around at my store for a corrugated hose that might take one of the boots place--- VUALA!!!
Part# WH41x10163
http://www.google.com/products?hl=en&rlz=1G1GGLQ_ENUS299&=&q=wh41x10163&um=1&ie=UTF-8&sa=N&tab=wf
I have these in my stock at work. Now you can make 2 boots outta one hose-- I cut it back a few notch's and this is the result - It does seal good around the lip of the plenum and fits snug on my carb
I will be cutting it down another notch to make the clearance - This was done on my 30min lunch
Let me know what you think
« Last Edit: July 08, 2010, 10:59:23 AM by DocVile »
Offline Gordon
  • 750K1, 550K2
Re: My Solution to Air Box -> Carb Boots "CB550 Guys"
« Reply #1 on: July 08, 2010, 10:45:45 AM »
It definitely does the job of connecting the air box to the carbs, but I would only consider it a temporary solution.  The stock boots are actually velocity stacks extending inside the air box.
DocVile
« Reply #2 on: July 08, 2010, 10:51:41 AM »
Yeah i noticed the velocity portion on my stock boots - ill see how this works until i can get stocks
« Reply #3 on: July 08, 2010, 10:53:53 AM »
Yes temporary only.  If you look at the stock ones.  Note the smooth inner diameter for non-turbulent airflow. And, you'll also see there is a step at the carb end to match the carb inner diameter to the coupler inner diameter?
Turbulent air flow causes rather odd things to happen while mixing fuel with it at different air speeds.  Carbs don't behave predictably with turbulent airflow in the throats.
Pretty good post apocalyptic fix through.   ;)
DocVile
Re: My Temporary Solution to Air Box -> Carb Boots "CB550 Guys"
« Reply #4 on: July 08, 2010, 10:59:52 AM »
Changed title to "My Temporary Solution" Sounds more Fitting   ;D
Offline gliderguider
  • Gliderguider
« Reply #5 on: February 03, 2011, 07:37:40 PM »
So where do you find new boots?
1978 CB550
2005 Royal Enfield 500 Deluxe
Offline Seabass
« Reply #6 on: August 12, 2011, 02:21:59 PM »
I just used some corrugated hose for a temporary fix on my cb550F like you said worked great for now untill i can track some boots down.Thanks DocVile
76 cb550 F cafe, 74 cb550 k
