Author Topic: Tell me what kind of compression gauge to buy  (Read 648 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: July 10, 2010, 05:43:25 PM »
Do they screw in where the plug goes or what? Can I pick one up at the auto parts store?
Offline hoodellyhoo
  • CB350F
Re: Tell me what kind of compression gauge to buy
« Reply #1 on: July 10, 2010, 06:09:21 PM »
DON'T buy a harbor freight one. Mine leaked right out of the box. Too bad I lost the receipt and couldn't return it.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: July 10, 2010, 06:16:16 PM »
There are some that screw into the plug hole, but you then need to make sure you have the right adapter to fit the threads.  Handy if you will be testing compression without an assistant (you don't need to hold the gauge AND kick the bike).  If you have an assistant, there is the type with a rubber tip that simply presses up to the plug hole.  The nice thing about these is that the tube between the adapter and the gauge is pretty short, giving you a closer-to-truth measurement.  The longer tubed setups are still useful as you mainly want to know the RELATIVE compression between the cylinders, not the absolute.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Johnie
« Reply #3 on: July 10, 2010, 06:32:32 PM »
I got this Craftsman system from Sears. Has all the adapters I need to use the SOHC plug holes. Nice case too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Old Scrambler
« Reply #4 on: July 10, 2010, 06:46:35 PM »
Johnie has the best system. The rubber-tipped units are OK but very difficult to get readings on the middle cylinders.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
